ATTN: Millermatic MIG welder owners...URGENT QUESTION
Discussion in 'The Garage' started by 84gmcjimmy, Apr 14, 2004.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Okay, I just FINALLY got my millermatic 135 hooked up today. Tomorrow I'm going to get practicing my beads, but I have come across a problem, how much do I open the gas tank on it? Slowly then all the way open, or what? I have 75% Argon, and 25% C02 mixture.(the two is the subscript) Thanks /forums/images/graemlins/thumb.gif
    READ POST AT BOTTOM
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    Re: ATTN: Millermatic MIG welder owners...
    open it all the way and set the regulator to 15 to 20, make sure you turn the tank off when you are done.
  3. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Okay, 'scuse my stupidity, but how do I set the regulator to that? And how do I know when I've set it up. I'd get my dad to help but he is really sick...
  4. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    Turn the screw on the regulator. You might first have to lossen the jam nut. Little different then most regulators.
  5. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Okay thanks /forums/images/graemlins/thumb.gif
  6. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    The proper name is actually a flow meter, and I was told to set it at 30 and more if you are welding outdoors or maybe less if welding indoors with no wind.
  7. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i had to tack weld something outside the other day and a little breeze, and the weld had a lot or porosity, that was on 25 /forums/images/graemlins/yikes.gif
  8. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    Flow meter is correct and 25-35 CFH (cubic feet per hour) is an acceptable range. The adjuster for the flow rate should be on the underside of the flow meter. Most flow meters have a couple of different scales depending on the gas being used and it's density. Make sure you're reading the scale for CO2...
    Rene
  9. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Okay, I went out and set it to 25, then when I tried to get a little closer to 30, it let out a high pitch scream, what would that be? And also when I open the bottle at, does it matter the PSI? Or am I supposed to adjust that too? Thanks /forums/images/graemlins/waytogo.gif
  10. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Also, is it dangerous if I weld on some rusty parts of a chunk of metal? I dont have a grinder handy so I sanded a bunch of it off, but there is still some there, will it be bad to weld over it? Thanks
  11. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    the gas part of that hting is going to cause you nothing but grief. i did myself a favor andbought some of that fluxcore wire it works great, with no gas /forums/images/graemlins/waytogo.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/grind.gif
  12. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Yeah I might buy some of that stuff for using outside, but its like 3 times more than the regular stuff where I get it /forums/images/graemlins/mad.gif
  13. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Be cautious of the fluxcore wire. I believe you have to change the liner before using the fluxcore wire then swap back when using regular wire. /forums/images/graemlins/thumb.gif
    I have never had any luck with the fluxcore wire but thats just my experience.
  14. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Wow. Really? Why do you have to change the liner... that could be a problem /forums/images/graemlins/doah.gif
  15. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    If using regular wire after using the fluxcore wire the regular wire will want to hang up on you because the fluxcore wire leaves a residue behind.
  16. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Oh darn. Thats no good. /forums/images/graemlins/mad.gif
  17. jimmy88
    jimmy88 1/2 ton status
    Feb 17, 2002
    351
    Detroit, MI area
    My little Miller says to change polarity when switching to flux core wire. Using gas I found the metal has to be really clean for any kind of good bead. Any rust or paint and it sucks. If you are just starting out do yourself a favor and get some clean metal to practice and learn on.
  18. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Okay,Ill scrounge for some cleaner metal. Thanks for the tips /forums/images/graemlins/thumb.gif
  19. lukebaby1
    lukebaby1 1/2 ton status
    Dec 16, 2003
    231
    Richmond, Virginia
    Ok first, you do not have to change the liner to run flux core. If you look at the inside of the flip up cover (where you put the wire on) it should have a decal showing the proper polarity for the type of wire you are running. .025-.035 wire should be used, just make sure you have the same size contact tip screwed in to the torch head that matches the wire you are using. If you are going to use sheilding gas, and you are welding outside in the breeze, then you will probably have to increase the flow at the regulator to compensate for the draft. I usually set it at about 10cfh and gradually increase to where I need it. Depending on what size bottle you are using, it can get expensive if you are running with more gas than you need. Most little bottles hold about 20-30 cubic feet. So if you run 20-30 cfh(cubic feet per hour), your bottle is only going to last about an hour. Also remember that the Miller 135 has only a 20-30% duty cycle, which means you can only weld 2-3 minutes out of every ten. Exceeding the duty cycle will overheat the rectifier/transformer in the machine and shorten it's useful life. Anytime you weld on rust, or paint, you are going to get weld contamination-flux core or solid. Flux core will probably show you a better weld through rust. Best way is to grind away the rusty areas, exposing the good metal. That way you get a good stong weld to the base metal. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/deal.gif /forums/images/graemlins/grin.gif
  20. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    Uhhh, the gas in those bottles is so compressed it's become liquid. CO2 is generally about 600 psi in the bottle. If you took all that CO2 out of the bottle until it was empty it'd probably take days at 20-25 CFH. Most Argon mix's are up around 1500 psi or more.
    Rene
