ATTN SCOBBYDANN SPRINGER SHACKLE FLIP
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DERBINATOR, Jul 27, 2001.
  1. DERBINATOR
    DERBINATOR 1/2 ton status
    Jan 26, 2001
    196
    YANKTON,SD
    I have been wanting to do this type of suspension from the first time I seen springers truck. Is he marketing a kit now? If he is were can I get some info? Costs?
    Did you use the ford springs or something else? Any info would be appreciated.
  2. ScoobyDann
    ScoobyDann 1/2 ton status
    Mar 9, 2001
    305
    El Paso, TX (Far West Texas near Las Cruses
    I've got all the information to get a hold of him to get the detailed info. for my setup it cost me $550 w/o the ORD flip but it came w/ everything (springs setup for 6"lift, his is a 4" so im sure he can do any average lift, drop bracket, track bar, stop brackets, shackles, and bushings. im not exactly how huch it would be for the regular setup (as in the origional shackle instead of the ORD) but i would think it would be a little cheaper. i know for a fact that if you do it to the regular shackle setup you can use it as a daily driver, cause he does and even drives it from Phoenix to El Paso and back at least once a year and then does wheeling trips in between and has NO problems. anyway here is his e-mail, just tell him scoobydann sent you
    marvin.springer6@honeywell.com
    sun desert offroad http://community.webshots.com/user/scoobydann
  3. DERBINATOR
    Jan 26, 2001
    196
    YANKTON,SD
    Thanks alot for the info.
