ATTN: those running hydro assist diff cover tab
Discussion in 'The Garage' started by muddybuddy, Dec 29, 2005.
  1. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    hey there, i was talkin to a guy and i told him i was wanting to get a diff cover with a tab for my ram on it (from KidJethro when me starts making them again) and he said that it wouldnt be strong because its only being held on by the diff cover bolts. i see his point and it got me second guessing this idea.
    is this not really that strong? if not, how should i mount mine?
    thanks
  2. ncgamedog
    ncgamedog 1/2 ton status
    Oct 7, 2005
    130
    union grove, north carolina
    im runing the MOO one w/ no problems. it may not be ideal but....
  3. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    diy4x makes them. they are plenty strong, you need to get longer bolts anyways so get some grade 8 ones and youll be all set.
  4. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    alright so the guy i was talkin to was full of $hit, good to hear :-) looks like ill continue with my original idea.
  5. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    the diff cover is held on with 10 bolts... assuming the cover is structurally strong enough, the bolt shear strength shouldn't be a problem. Hydro rams can produce an amazing amount of force, but you'd prolly break a tie rod end before you sheared 10 grade 8 bolts off...
    j
  6. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I can see there being an issue with leaks though. Without a tight dowel pin or two I could imagine the cover moving around a bit under force as the bolts aren't a tight fit in the holes. I think I'd fit a couple of 3/8" dowels to it too.
  7. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I intend to buy my ram mount from DIY4X his is just a mount that bolts ontop of the dif cover and can be set up for heims or clevis ends. Made from 1" I believe. It is on his site if you need pics.
    Ira
  8. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Kert at DIY4x made me a custom ring. Imagine one of his do it yourself cover rings humping his hydro assist mount and you've got it.
    It's just a ring with a large flat area off to the side with a clevis end mounted on it...has worked fine so far and I definitely don't anticipate it breaking. I flopped my rig last time out and the hydro assist had enough power to lift the truck up sideways. I'm not worried about it.
  9. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    Go with DIY4x mount looks beefy enough.
    Jesse
  10. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Heres mine. Diff doesnt leak, never has.
  11. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Sweet Jesus that diff cover is thick!!!
  12. CK5
    May 19, 1999
    21,623
    701
    CO
    It is strong enough, but it will leak when you wheel hard, mine is mounted this way until I go coilover in the front.
  13. primetime
    primetime Registered Member
    Jul 18, 2005
    22
    sa,tx.
    well alot of the austin k5 group have that same set up & the wheel
    hard & never seen one of them leak(yet):bow:
  14. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Im the only one in the group running mine to the diff.
    Ow the "ring" is 1" thick and the guard and ram tabs are 1/4".
    The holes in the ring are almost a hammer tight fit so that probabaly helps with the cover not moving around. Im just saying that I have wheeled it and the only thing leaking on that front axle is the pinion seal:laugh:
  15. bdozeraz
    bdozeraz 1/2 ton status
    Nov 8, 2004
    212
    Phx, Az
    I'm running my ram off of a blue torch fab cover. It has a 3/8" thick bolt ring and 1/4" on the rest of the cover. I've had my bolts on the cover loosen once but I think the gasket was still seating. I retightend the bolts and have checked them several times since and they are still tight. I also thought about a couple of dowel pins, seems like it would be a good idea.
  16. primetime
    Jul 18, 2005
    22
    sa,tx.
    sorry. i thought rusell & john(i think were running the same set up)
    well thats what i get for thinking.:doah:
  17. primetime
    Jul 18, 2005
    22
    sa,tx.
    sorry. i thought rusell & joe(i think were running the same set up)
  18. primetime
    Jul 18, 2005
    22
    sa,tx.
  19. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I was just thinking countersink bolts would negate any slop there may be in the holes of a diff cover ring. Maybe even re-tap them to the next larger size. :thinking:
  20. fordtruggy
    fordtruggy Registered Member
    Dec 30, 2005
    55
    Red neck ville Rapid city SD
    I have seen guys run full hydro on mount welded to the stock dif cover and has never had a leak or problem..Just curious,How big of a tire can you run with ram assist?
