ATTN VENDORS; Possible Fab Idea
Discussion in 'The Garage' started by nvrenuf, Sep 21, 2005.
  1. nvrenuf
    Jan 7, 2002
    13,076
    246
    Mobile, Al.
    With all of the 52, 56, etc front spring swaps why doesn't anyone make something like these? I know they would cost $ instead of using the free hangers your removing but with the front eye adjustability it would seem to cure all of the good/bad shackle angle scenerios. I know the frame horns changed over the years but aren't they similar enough to do this?
  2. big94gmc
    big94gmc 1/2 ton status
    Sep 1, 2004
    3,651
    No VA.
    Where'd ya get those pics, John?
  3. nvrenuf
    Jan 7, 2002
    13,076
    246
    Mobile, Al.
    Rad sent me a few links about things he may/may not do to his Dodge and I saw this on one of the pages. The bracket is simple and the idea of multiple holes seems so obvious (now that I've seen it :doah: ) I'm surprised no one is making them.
  4. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Is it held on with anything more than the 2 bolts through the frame?
  5. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    looks like it has one or two more behind the gusset.
  6. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Thats a cool idea but unless the spring was mounted in the very front hole,I would bend those up crashing into rocks :D
  7. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    gee.....thanks for the idea, think i myts bes makin me somea those. :D
  8. alf4444
    alf4444 1/2 ton status
    Nov 1, 2002
    2,051
    T-ville, ut.
    Those are a good Idea makes me miss my front frame horns :crazy:
  9. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Definitely has possibilities!
  10. nvrenuf
    Jan 7, 2002
    13,076
    246
    Mobile, Al.
    I was hoping you'd see this. :D If you decide to make some, put me down for the first set!
  11. k5 krawler 50
    k5 krawler 50 1/2 ton status
    Jan 26, 2004
    1,467
    Gardnerville, NV
    Thats some what along the same lines i was designing up. I wanted to keep the stock bumper mount holes, and was figuring out a way to do this. That set up that you pictured seems to be a great idea. Sweet find.
  12. nvrenuf
    Jan 7, 2002
    13,076
    246
    Mobile, Al.
    TTT
    Just thought I'd bump this for people to see and check interest since Kert is considering making them. :thumb:
  13. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I would def buy a set of those as I intend to go to 56s up front and I already have a bumper that I would prefer to not rework the mounting of it. They look pretty beefy also.
    Ira
  14. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    I'd def. be up for a set when I do a spring swap. My current plan for a winch mount will render the "traditional" method useless.
  15. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,015
    848
    Pinckney, MI
    I would be up for a set for the 56 swap I plan on doing in about 6 months
  16. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    ami right in thinking that with those you would not have to move the rear hanger with 52's
    if so i would buy a set
