auburn pro series limited slip lube
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by motorheadnelson, Dec 25, 2004.
  1. motorheadnelson
    motorheadnelson Registered Member
    Aug 12, 2001
    80
    Fort Mohave AZ
    Was wondering what guys have good luck with. I used Valvoline dino gear lube with GM modifier. Starting to get noisy, 12K. Any suggestions? Thanks
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    That is what I was told to run when I had a Auburn LS. Gear oil with 1 bottle or GM LS modifier fluid.
    Harley
  3. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    Amsoil synthetic gear oil. Check to make sure, but I don't think you'll need friction modifier if you use Amsoil.
  4. JonV
    JonV Registered Member
    Mar 17, 2003
    27
    Hesperia, CA
    What viscosity gear lube are you using? What's your ambient air temp?
  5. JonV
    Mar 17, 2003
    27
    Hesperia, CA
    P.S. When you changed your gear lube did you use a solvent to flush the diff? If so, and some solvent was left in there it would break down the new lube prematurely. I only flush with new gear lube.
  6. joefl
    joefl 1/2 ton status
    Aug 18, 2004
    153
    Marianna, Florida
    I have an Auburn Limited slip in my Z71 and it started to get noisey so I changed the oil and that quieted it back down. I used the oil that they had a dealership parts department. One bottle of gear oil to one bottle of GM limited slip oil.
