Aussie Jack Adapter
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 84k5, Jun 22, 2001.
  1. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    This is in the current issue of Four Wheeler. Any thoughts?
    http://84k5.coloradok5.com
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Looks like a neet idea. Too bad you can't change a tire with it!
    '71 Blazer CST with alot of rust
  3. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Hmmm, duno if I like that! It is too close to the hub's dial and I wouldn't want the weight of my rig resting on that part. I think I will stick with the old fashion way to lift my rig off the ground........
    <A target="_blank" HREF=http://www.burt4x4.coloradok5.com>http://www.burt4x4.coloradok5.com</A>
  4. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    You can do the same thing with beadlocks.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  5. Logan
    Logan Registered Member
    93
    Fournier, Ontario, Canada
    And you thought your auto hubs didn't work properly before! ;)
    -Al.
  6. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I don't think my pretty little center sleeves will hold up to that.........
    90K5
  7. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    So what happens if you want to pick up the rear end?
    "There is a fine line between hobby and mental illness"
    Luke
    84 K5
  8. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    just need to upgrade to full floating axles
    1974 Chevy Blazer Cheyanne. lots of plans for it....
    but it is on 33's now, with saggy old springs. i am in so cali if ya got any parts for me.
  9. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    It looks like it'd eat your hub and then spit it back out if it were even a slight bit not right.... you can't change a tire with it.... and who installs show chains by jacking up their truck anyhow? I never have done it that way...! I can see it for like the rut thing... because the high lifts make me nervous with just that little contact of metal holding you up... this looks like it wouldn't slip off... but then you try to drive and go forward and it's on the hub, so that wouldn't work now would it... so um, what exactly does it do better? He he [​IMG]
    "Suck Fumes Ford Boy"
    "I love my country, I fear my government"
    <A target="_blank" HREF=http://www.chevycagal.homestead.com/steph.html>http://www.chevycagal.homestead.com/steph.html</A>
