Austin Hardware- Weld on hinges
Discussion in 'The Garage' started by FWP, Mar 3, 2005.
  1. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Anybody buy any of these? There's no pictures on their website.
  2. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    If they're the same weld on hinges I have used in the past they work awesome. They can be a little tricky to set up though, it's really easy to get a slight misalignment.
    A place I used to work at built custom steel belly boxes for gravel trucks, and big trailers, and all the boxes had weld on hinges. They make them in aluminum too. We'd often mix and match the aluminum and steel weld on hinges so we could put aluminum doors on a steel box.
    Rene
  3. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    OK, thanks man. I'm planning on a different tube door design, and wondered what they looked like. Maybe I'll call em on Monday, and see if they can shoot me some specs.
  4. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
  5. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    They have a pic on the site...
    http://www.austinhardware.com/dept.asp?dept%5Fid=219
    If you were to rotate the right hand half of that hinge you'd see the same 'tab' that the left shows. That is the area you weld on each half.
    Rene
  6. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    They have shorter versions of those hinges at the local steel yards in phoenix. I saw one up to a 5/8" pin. They use them for heavy duty gate use, they are greasable and cheap too. IIRC the 1/4" pin (most reasonable in size) is a little longer than 2" toatal (inch on door side, inch on hard mount side).
  7. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    The link I posted shows them all the way up to 3/4" pin diameter and 10" total length.
    The most common ones we used were 5/16" pin and 3.5" long.
    Rene
