AUTO CHOKE AND BLACK SMOKE!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JimmyJuneau, Nov 2, 2001.
  1. JimmyJuneau
    JimmyJuneau 1/2 ton status
    Apr 11, 2001
    811
    Juneau, Alaska
    I have a stock 305 on my 85 jimmy with a stock carb. I just rebuilt the carb but I am still having problems with the choke not kicking on and I also have problems on colder days when the carb is sucking in way too much gas the truck is bellowing out the back with black smoke. Now I need to know what to do and how to fix these problems. Any help would be appreciated as winter is setting in.
    Where does the auto choke wire go to after it leaves the heating coil? Is it the blue wire that connects to a plastictube by the starter?
    1985 GMC JIMMY<P ID="edit"><FONT class="small">Edited by JimmyJuneau on 11/02/01 10:43 PM.</FONT></P>
  2. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    you'll need to start poking around with a tester to see whats up. I think there is a sensor that gives the choke juice after its started, other wise there would be no point in having the choke pull off before its started. See if its getting power first and we'll work from there.
    <a target="_blank" href=http://www.geocities.com/bigkern76>http://www.geocities.com/bigkern76</a>
  3. JimmyJuneau
    Apr 11, 2001
    811
    Juneau, Alaska
    Ok I checked it ou this morning it is getting power
    1985 GMC JIMMY
  4. Blazer_Boy
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Well your choke could be out of adjustment or more likely, its junk. They're really easy to change, just a few screws. Once its on you can adjust by turning the big thingy in the middle to set it for lean or rich.
  5. JimmyJuneau
    Apr 11, 2001
    811
    Juneau, Alaska
    More importantly right at this moment I need to find out where the wire goes from after it leaves the choke coil?
    1985 GMC JIMMY
