auto darkening welding helmet question???
Discussion in 'The Tool Shed' started by twoslo4five0, Mar 27, 2007.
  1. twoslo4five0
    twoslo4five0 3/4 ton status Premium Member GMOTM Winner
    Oct 5, 2006
    6,614
    71
    Living in a dump, VA
    i was using my lincon auto helmet today and the auro stopeed working...whats up with this???anyone know???
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    so it stays dark or light?
    is the lens clean? the sensors can't pickup anything if its too dirty.
    new batteries?
  3. twoslo4five0
    Oct 5, 2006
    6,614
    71
    its a brand new helmet...i just started using it like 5 mins before it messed up...it stays light...i was welding set it down,changed rods and when i went back i was like wow this rod is brighter then i relized it wasnt working proerlly...
  4. runamok151
    runamok151 1 ton status Premium Member
    Oct 24, 2005
    12,542
    1,455
    the armpit of the east coast, 08046
    maybe the batteries? if it was sitting on a shelf for a while they could be dead. make sure the wires are hooked up inside.
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Go set it in the sun for an hour or two. If the batteries get to low they won't work. If that doesn't work then :dunno: .
    Harley
  6. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    is it solar or battery or both? batteries are cheap, and even cheaper from a factory...
  7. twoslo4five0
    Oct 5, 2006
    6,614
    71
    i dunno i know nothing about it but im sure im about to find out real soon i guess...
  8. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    Dude, it's easy to see if it's battery or solar. Does it have a solar panel for charging it, or not...
  9. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    My hobart is battery with a solar charger. Welding lets the solar panel charge the battery, but if the battery sits for to long it can discharge & not darken the helmet. If that happens you put it out in the sun for awhile so the sun will charge the battery & make the helmet darken again.
    Harley
  10. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    My helmet must be weird...
    with it turned off, its dark
    when its turned on, its light
    When you strike your arc it darkens
    battery dies or it times out, it goes dark :thinking:
    Battery only, no solar.
  11. balterbuilt
    balterbuilt 1/2 ton status
    May 10, 2004
    385
    Santa Rosa
    is it turned on? Some you have to push on the lens and it will flicker to turn them on, maybe it wasn't on.
  12. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    The button for mine is a real pain, its inside the helmet. I have to pull my glove off and reach in from the top of the mask to hit the button. Its dark all the time (off) its about a 13shade, when you hit the on button the mask becomes see through about like the glasses I use with the cutting torch (maybe a 3-4, real dark sunglasses). It has a sensor in the front and when you strike an arc the mask turns black (to whatever shade you set it too, I use about a 9 or 10). I'll try to snap some pics today, I'll post when I get back to my place Sunday.
  13. balterbuilt
    May 10, 2004
    385
    Santa Rosa
    send it back..haha
  14. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    this is off
    this is on
    the way I understand it, it is like a LCD display.
    In the off mode its closed _v_v_v_ (its dark as if it where a std welding shade)
    In the on mode its open |V|V|V| (its open, allows in more light, once the arc is striked it reverts to the "closed" position for welding)
  15. balterbuilt
    May 10, 2004
    385
    Santa Rosa
    taht is correct, it is an lcd screen ,sometimes you can see the dots too. It should be real light when it's on and darken once an arc is struck. If it's not doing that it might be broken. Also, is there a grind mode on the helmet? If it's stuck in grind mode then it wont darken much once an arc is struck.
  16. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    no gride mode, it works for what I use it for
    when I run the torch/grinder I have a pair of the blue-blocker-lookin green goggles
  17. balterbuilt
    May 10, 2004
    385
    Santa Rosa
    i don't kowi would call the manufacuterer and try to get a new one or see if they know what it is.
