Auto Door Lock
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by johnny reb, Feb 4, 2002.
  1. johnny reb
    johnny reb 1/2 ton status
    Mar 6, 2000
    326
    Pittsburgh, PA
    I took off my passenger side door panel yesterday to fix my power window and the auto door lock on that side is screwed up now. The auto switch on both doors only unlocks/locks the drivers side door now. I can't get either switch to work for the passenger side door. Any ideas on what went wrong?
    1986 K5, New GM 350, Edelbrock Intake, K&N Air Filter, Flowtech Headers, Dual 3" Exhaust, 33" Pirelli Scorpion AT, 700R4, 3.42 gears
  2. 85Jimmy
    85Jimmy Registered Member
    Oct 30, 2001
    97
    Great Falls, Montana
    I have the same problem with mine only it's on the drivers side, both motors are good, must be the wiring, I don't know!!!
  3. holyjohnson
    holyjohnson Registered Member
    Nov 22, 2001
    94
    the fringe of insanity (only on mondays)
    ive got the same problem on my 85 burban doorlocks only lock and unlock passenger sides from drivers.and i did almost everything to figure it out from changing power locks to lubing it to chasing the wires and still havent figured it out.
    goodluck
    "well,are you gonna pull them pistols,or whistle dixie!?"
  4. ducati-cooter
    ducati-cooter Registered Member
    Jan 24, 2002
    78
    Madison WI
    Hoolyjohnson, Your problem sounds like a simple switch, if you can lock and unlock both doors from the dr side and not eh pass side it more likely to be a switch. If nothing on the pass side works, check all grounds for that door. I have seen a loose and rusty ground cause a probplem like this.
  5. 85Jimmy
    Oct 30, 2001
    97
    any ideas for mine both switches only do the pass side? Chris
  6. holyjohnson
    Nov 22, 2001
    94
    thanks for the info.
    it drove me crazy for a long time to hit the drivers side lock and it only locked and unlocked the pass side doors and didnt do anything on either driver side.i actually pulled out the switch on the drivers door and re-grounded it but havent done the drives side rear yet.i plan on swapped out the drivers door switchs and running a wire and powerlock to the cargo doors too.but thanks for the input.
    goodluck
