Auto or Manual Trans
Discussion in 'The Garage' started by rickmack1, Apr 15, 2004.
  1. rickmack1
    rickmack1 Registered Member
    Aug 24, 2001
    45
    Florida
    Whats better?
    Automatic Or Standard?
    That is the question! /forums/images/graemlins/ears.gif
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Uhhhhhhhhhhh, for what type of driving?
  3. dyeager535
    26,979
    What do you prefer? That's your answer. /forums/images/graemlins/smile.gif
  4. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    This an age old question that has caused many a heated debate on these boards.
    I love my auto.I dont ever see myself swapping it out for a manual /forums/images/graemlins/grin.gif
  5. rickmack1
    Aug 24, 2001
    45
    Florida
    Not a daily driver. It's 39.5 boggers, 10" lift, built for show n go. I'm able to trade my 400 turbo and 205 transfer case for a 4 speed manual with same transfer case. I like standard trans because of durability but I just want to get other opinions about this option.
  6. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    I prefer manual. All my work trucks have the 3spd + low gear. I think a manual is just more durable and dependable. I've limped a manual tranny home with everything from no 1st or second gear to no clutch. It does take a bit of practice to shift without a clutch I will admit but try driving that auto tranny home with a fragged torque converter. Then there is also the advantage of the pop start if the battery goes dead for some dumb reason. A manual is far less tempramental with heat...at worst usually you'll burn up a clutch before hurting the tranny internals and a clutch is relatively easy to replace compared to rebuilding a tranny that overheated.
    so umm...I like the manual.
  7. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    I perfer manual because that's what my dad taught me on, but I have a auto in my blazer, and manual in my Jimmy, so it's all about what kind of 'wheeling you do. If its show and go like you said then I dont think it matters. personal preferance I guess is the big thing.
  8. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    I like my manual. But if I had a 400/205 set up I think I would stick with that.
  9. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    If I had a 400/205 I'd keep it, but since I don't I'm swapping in a 465/205 with 32 splines and a hydraulic clutch to power my 39.5" Bogger with 5.13 gears. I'll need all the gear I can get with a stock TBI 350 and dual lockers /forums/images/graemlins/peace.gif
  10. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I like my auto for a couple reasons. The torque converter makes use of higher gears possible, and I ran out of money before gears. I have less pedals to work with when wheeling. But of course its ultimately going to be your decision, so get what you feel comfortable driving with /forums/images/graemlins/k5.gif
  11. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Standard all the way. So many advantages compared to an auto. Cheap to buy and last forever. Mucho coolness factor. /forums/images/graemlins/peace.gif Automatic transmissions are the DEVIL. /forums/images/graemlins/angryfire.gif
  12. madmike
    madmike 1/2 ton status
    Jan 23, 2002
    496
    ohio
    standard!
  13. gravdigr
    Apr 15, 2003
    1,129
    Tyrone, PA
    I'd take the 6.33:1 low gear of a manual over the maybe 2:1 torque converter. Luckily I have EEE feet so I can work the clutch and brake at the same time for those tricky places /forums/images/graemlins/thumb.gif
  14. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    it's 6.55:1 and 7.02:1 for the SM420 (I think) What's the most you'll get with a torque converter in first gear? Maybe a 3:1 first gear and 2:1 for the TC making it a 5:1? /forums/images/graemlins/dunno.gif
  15. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Generally, you multiply the ratios together. That would give you 6:1.
  16. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    You're right, I either slipped or forgot how to do math /forums/images/graemlins/blush.gif
  17. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Full reverse manual valvebody with compression braking and pushbutton lockup in a 4L80 is the way to go in my opinion.
    I'm not going to complain about my 700R4, loose torque converter, and NP208 though. AKA poor man's doubler.
    I wouldn't complain about having a SM465 or SM420 either, especially in a trail vehicle.
    I'd never put a TH350 or NP203 in any vehicle though. In my opinion TH350s are for station wagons and NP203s are for boat anchors. I wouldn't replace a 700R4 or SM465/SM420 with a TH400 either but I also wouldn't complain too much about it.
    It is all based on personal preference. However, the first thing in the list is the Grand Master as far as I'm concerned. It even beats the NV5600 in my book.
  18. tucsonkfive
    tucsonkfive 1/2 ton status
    Jun 9, 2002
    133
    Tucson, AZ
    Call me lazy but I love my auto. /forums/images/graemlins/pimp1.gif
  19. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    auto. the lady likes to wheel, and she can't hit the brakes withoput a 2x4 strapped to the pedal. no way she could handle a clutch too
  20. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Ya lazy bastid! /forums/images/graemlins/grin.gif
    I like to row ma own gears...SM465!
