auto overdrive vs. 4spd & Gear Vendors
Discussion in '1936-Present Suburban' started by k14, Feb 10, 2007.
  1. k14
    k14 Registered Member
    Aug 30, 2006
    30
    So.Nv.
    I have a '66 suburban with the original 4spd. and the divorced Rockwell t-case. I can't decide if I shoud swap in a 700R4, 4L80E, or just add a Gear Vendors to my original drivetrain. The autos would be easier to drive, but the 4spd. granny low first is great off road and being able to split gears seems like it would make for a better tow rig. What do you guys think? Anyone have expierence with any of these trannys in older rigs? Thanks.
  2. CDA 455
    CDA 455 3/4 ton status
    Jun 2, 2006
    8,598
    43rd State
    New GV cost big bucks. Try to find a nice used one.
    And, are you sure they have an adapter for your tranny?
  3. k14
    Aug 30, 2006
    30
    So.Nv.
    Yeah, I know the GV OD is expensive:yikes:, but I have a line on a good rebuilt one. The guy at a local drivetrain shop told me I should adapt it to the transfer case. I really wouldn't need it in 4wd anyway and the driveshaft between the tranny a t-case isn't very long.
  4. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    If you have a line on a rebuilt for cheaper than 2k go for it.
    Just in case it wasn't clear, I meant the GV overdrive.
  5. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    What are your driveing plans for it? how fast or slow do you need to go?
    I have a 465 in my burb, the granny gear was an dubble low range before I had a dubbler.
    If you plan on towing with it, you wont be using the OD gear anyways.
  6. k14
    Aug 30, 2006
    30
    So.Nv.
    I plan to use it occasionally to tow my boat, and I only live like 3 miles from the launch ramp. Right now I have an SM420 tranny and 4.11 gears with 35" tires, but I'll be puting on some 37 inchers real soon.
    I really want an OD for cruising on the highways. I was just wondering if anyone had any expierence with a Gear Vendors and a 4 spd? Thanks for the replies.
  7. desertrat67
    desertrat67 Hawk Driver
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    I ran 38s with 4.10s and my rpm range was great. My BB ran around 2500-2700 at 70mph.
