auto shifter linkage keeps coming loose!
Discussion in 'The Garage' started by bryguy00b, Dec 29, 2003.
  1. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    any one else have this problem!!? just for the recrod..i got a 700 trans, and i have repeadedly re adjusted the linkage, because the bar or w/e from the column keeps slipping in the rod going to the tranny, so i can only shift into like p,r,n,d. and i have to pull the hell out fo the shifter upward to be able to turn the key. i have re adjusted this to fix it lik 10 times and its fine for a few weeks then all of the sudden i will come out to the truck, and discover i only can shift into those 4 options..am i doing something wrong? all it is is a friggen screw you lossen and retighten..i dont get why it keeps coming loose.. /forums/images/graemlins/confused.gif /forums/images/graemlins/1zhelp.gif
  2. mccomas
    mccomas 1/2 ton status
    May 30, 2003
    262
    Fayetteville, NC
    is the washer in place on the adjustment bolt? i think it keeps the adjustment bolt from moving right and left. maybe the adjustment bolt has worn a grove on the rod and it is not getting nice and snug - pick up a new bolt that is just a bit longer and give it a try...
  3. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    ok ill do that then...yea the washer is on there....somethings goofy with it..took like 5 attempts to get it to just stay in position to allow me to shift in al lthe gears...
