Auto to man. swap Q's
Discussion in 'The Garage' started by Geargrinder, Feb 6, 2005.
  1. Geargrinder
    Geargrinder 1/2 ton status
    Jan 21, 2005
    258
    Medford Oregon
    O.K., I have an '86 Burb, 700R4, NP208. I have an '84 Burb, SM465, 208.
    I will be swaping the SM465 into the '86, but the cluch pedal I'm not sure on.
    Will the cluch pedal ass. just bolt into the '86? I know that I need to cut a hole in the floor for the rod to pass through. It's the pedal it's self that I don't know about.
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Look up under the dash for mounting points. If there isn't any from the factory, you'll have to fab up something.
  3. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    they should, in my 86 pu i put pedals from a 79 in, they bolted right up, then i put some hydro pedals in and bolted right up
  4. dyeager535
    26,980
    I know you've got the stuff for mech., but if you can get your hands on the hydraulic stuff, it would be an easy (and better) swap. The '86 has all the points/dimples for the hydraulic clutch stuff.
    Just an idea if you can find the hydraulic stuff cheap/free. I know in some places it's not tough to come across.
