auto to manual hubs what do I need to swap them
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by James90, Nov 8, 2000.
  1. James90
    James90 1/2 ton status
    May 18, 2000
    986
    Rocky Mount NC
    what do I need to convert the stock auto hubs on my 90 to warn manul hubs? and what tools do I need to do it?
    does 80.00 sound good dor warm premeun hub or is it to high?
    thanks
    [​IMG]Go prepared
    I have a Shotgun a Rifle and a 4WD(K5) and Country Boy Can Survive!!!!
  2. Todd78/87
    Todd78/87 1/2 ton status
    Feb 18, 2000
    436
    Haines, Ak
    The only special tool you need it the GM Hub socket,,,, Nope,, $80's not to bad for Warn Premiums
    Todd 78/87[​IMG]
    Haines,Alaska
  3. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    A dental pick for the big snap ring and lots of patience trying to get it out, other than that, its pretty simple. Just read your directions
    creepin' and crawlin'
    Jim
  4. backlash
    backlash 1/2 ton status
    Oct 21, 2000
    519
    Northern, VA.
    Just curious ... Why would you switch from auto to manual? Are they stronger?
  5. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
    Where can u get a hub socket? Yes, the manual ones are stronger.
    Dawson
    88 K5
  6. Todd78/87
    Feb 18, 2000
    436
    Haines, Ak
    Any auto store,, AutoZone, Western Auto, Pep Boys,, Whatever,, they are in the isle with the other 'special' tools.
    Todd 78/87[​IMG]
    Haines,Alaska
  7. Russell Keys
    Russell Keys 1/2 ton status
    Mar 16, 2000
    253
    Huntsville, TX
    What special hub socket is needed? I'm going to switch from auto to man. hubs on the 83 I bought. I've never personally known about a hub socket for removing the hub. Oh btw has any one used milemarker hubs? They are priced a little better ($50.00-$60.00)and have a lifetime warranty like the warn premiums.-Russell
  8. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    Its about a 2 inch socket with four prongs that match up to the spindle nuts. It's been a few years since I swapped mine out but it was pretty simple. The hardest part was getting the snap ring out.(it fits inside the wheel hub and keeps the locking part of the assembly in place)
    Jim
  9. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    Don't need a spindle nut socket to change hubs. Will need a torx socket not sure what number. Stock is torx head replacment man. hubs use allen heads. Will also need snap ring pliers. And yes a dental pic or any pointed tool will work to remove outer snap ring. I just ground down an old screwdriver.
  10. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I didn't need the hub socket to take out the actual hub mechanism out itself, you need the socket to take off the outer bearing and the rotor.
    [​IMG]FUN WITH 31's![​IMG]
  11. James90
    May 18, 2000
    986
    Rocky Mount NC
    thanks guys I am going to buy them in a day or two
    [​IMG]Go prepared
