Auto to Manual Hubs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by pr1aw, Feb 18, 2001.
  1. pr1aw
    pr1aw 1/2 ton status
    Sep 17, 2000
    144
    San Diego CA
    When changing to manual hubs, do you just pull the autos and drop in the manuals?
  2. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    I have heard stories about conversion kits and the like. I pulled my autos and put in superwinch hubs. Direct bolt in, had it all done in under 20 mins.
    Luke
    84 K5
  3. baldbandit
    baldbandit 1/2 ton status
    Jun 16, 2000
    282
    Marshall TX
    I have a dana 44 and 203 combo. I was looking at the hubs today and was wondering how you convert them? There is nothing to unbolt! Just a chrome cap at the end of the hub. The hub and rotor are one piece. Can i convert these or will i have to buy another rotor and hub assembly? Any help is appreciated!
    baldbandit
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    To change from auto to manual hubs, just take out the guts of the auto hubs and install the manual hubs. It's pretty easy.
    To change from full-time 4WD to locking hubs, just pry those chrome caps off. They're just dust shields. Then you can get to the guts of your hubs. Also an easy swap. Remove a couple of spring clips, slide out the machined slug that provides the connection between the hub and axle, then install your locking hubs.
    FYI, the hub and rotor are actually 2 parts. They're held together by the wheel studs. Remove all the studs and the 2 come apart.
  5. Emmettology 101
    May 9, 2000
    8,126
    FL
    On the hub part, Harry got it down pretty well. However, if you haven''t converted your t-case(203) to part time, then you will have to do that also!
    They sell kits for this.
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
  6. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Yep! Gotta convert the t-case to part-time. Otherwise everything up front will be spinning anyway (and you'd have to run in 'loc' all the time to even move).
