auto to manual hubs
Discussion in 'The Garage' started by obijuan, Jun 25, 2006.
  1. obijuan
    obijuan 1/2 ton status GMOTM Winner
    May 18, 2006
    4,009
    San Antonio TX
    my auto hubs keep failing to disengage, and i want to have manual hubs. what kind of trouble am i looking at to switch them out. how long would it take and any problems like adapter kits needed? which hubs are decent hubs and what am i looking at to spend. thanks alot for your help
  2. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    how can you tell if they stay engaged? i think mine are too.
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    swapping auto to manual hubs is pretty easy. I personally run and like Warn Premium locking hubs. They have taken a beating from me and still work fine. They also have a lifetime warranty should you break one.
    The swap process is pretty easy with fairly simple tooling.
    1. Remove auto hub cover
    2. Remove snapring on axle shaft
    3. Remove snapring from wheel hub that hold the locking hub body in
    4. Remove hub body
    5. Remove axle snapring behind hub
    6. Slide in new manual hub body
    7. Install wheel hub snapring
    8. Install axleshaft snapring
    9. Install manual locking hub dial
    10. Drink Beer if you weren't drinking during the process of swapping hubs.
    The hub dials are usually held on with torx or hex screws. A set of snapring plyers are very useful along for the axleshaft snaprings. A set of small dental style picks or eyeglass screwdrivers is great to get the wheel hub snapring out. The wheelhub snapring is hard to see. It is just a small wirelike ring that clips in a little groove on the inside of the wheel hub. Once you get both snaprings out you take one or two of the dial bolts and thread it into the hub body to help pull it out with.
    Only use a LITTLE grease on the new hubs when you install them. Just a dab here and there is plenty.
    Harley
  4. thfonz98
    thfonz98 1/2 ton status
    Feb 19, 2005
    319
    Salinas, ca
  5. WhiteBurb
    WhiteBurb 1/2 ton status
    Mar 10, 2005
    307
    Louisiana
    It took me around 1 1/2 hours to swap mine out, and I had never done it before. I've got the warn premiums also.
  6. obijuan
    May 18, 2006
    4,009
    San Antonio TX
    thanks for the help! thats what i needed to know, the way i can tell its not disengaging is it makes a really loud t-t-t-t-t-t-t-t-t-t when you drive in 2h with one still locked, and your driveshaft turns. thanks again for the info. much appreciated
  7. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    Im pretty sure the front diveshaft turns regardless of the hubs being locked or unlocked. IIRC
  8. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    The driveshaft does turn some during normal driving in 2wd. It doesn't turn as fast as the rear shaft though. It turns from parasytic drag. The front shaft will spin slowly under most conditions. If it is spinning full speed then a hub is not dissengaging.
    Harley
