auto to manual hubs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by txbluethunder, Aug 17, 2002.
  1. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    well i finally got my warn premiums and i got the outer cover off, popped the ring off the splined shaft and got to the point to push in the tabs on the big ring to pull the carrier out and it won't come out. i can move it around some like there's slop and i can compress the ring tabs but it just won't pull all the way out...is there something i'm missing here?
  2. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    Did you get the big ring that is in the groove at the edge of the hub...get some dental pics at the store and you can feel it in the groove and pull it out ...mike
  3. txbluethunder
    Jan 29, 2002
    835
    Austin, TX
    yea...i got the ring that holds the big f'n spring off. its the ring that pins the carrier into the axle housing that i can't get to release all the way.
