Auto to manual swap question
Discussion in 'The Garage' started by cegusman, Jan 21, 2003.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I have a 6.2 w/700r4 trans, I know I need to swap out the flywheel for a diesel one. What about the ring gear can I use the one from the auto trans?
  2. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    where did you find a flywheel without a ring gear?
  3. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    All of the auto flexplate rings I've seen are welded on.You should be able to get new one from dealer.Every thing else should be easy swap with stock parts. /forums/images/graemlins/crazy.gif /forums/images/graemlins/truck.gif /forums/images/graemlins/thumb.gif Need to add.Not hard to put on flywheel.I put flywheel in fridge{not freezer}till cold,then law it on flat surface and heat ring.It should slide down onto flywheel and seat itself as it cools.Has worked well for me several times.Hope this helps /forums/images/graemlins/thumb.gif
  4. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
  5. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    The second link shows the flywheel, pressure plate and hydro bell. The flywheel has a ring gear on it...
    Rene
  6. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    buy the 2nd one right now before someone on here sees it.
    the first link is a rip off
  7. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Does the second one have the flywheel or is that just the ring gear? nevermind just read the above post will try to win item. thanks
  8. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    Too bad you werent closer...I have a 6.2 flywheel in my garage from my mom's boyfriend's truck. He converted his to a 350.
