auto to manual tranny swap
Discussion in 'The Garage' started by LAXandBLAZERS, Nov 9, 2003.
  1. LAXandBLAZERS
    LAXandBLAZERS 1/2 ton status
    Jun 2, 2002
    100
    Durham North Carolina
    How hard is it to do a 700R4 To sm465 swap in a Blazer? Is there a lot of fabrication needed???? How long would it take? And anyone who has done this what is a ballpark figure in what you have spent? Thanks for the help. Kepping all options open.
    /forums/images/graemlins/k5.gif
  2. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    My friend did it. He needed a flywheel, the tranny t-case a jig saw a drill, (possibly a new pedal assembly). you may also have to alter your driveshafts as they may be a different length. He did the swap behind a 6.2L
    Thats about it. Pull all the old stuff out, shove in the new stuff, and cut holes where you need. Also, just take care in the "little" stuff like speedo cable etc.
  3. LAXandBLAZERS
    Jun 2, 2002
    100
    anyone else who has done it?
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I did it. I needed flywheel, clutch, 465/205, pedal assembly and clutch linkage, got the rear driveshaft made. I suppose to do it right, you'd need a manual column too.
    $140 for the clutch assembly, $180 for the driveshaft, $50 for clutch linkages.
  5. LAXandBLAZERS
    Jun 2, 2002
    100
    well, where is the best place to find a SM465/205 combo? My dad's old truck had one and thats about the only one I've seen around here. Where should I look? Thanks for /forums/images/graemlins/k5.gif the help
  6. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    We really need to do a write up on this. I see you have an 86 so you shouldn't have problems finding the flywheel.
    Where should you look?? Every junkyard you can go to. Also depends on what transfer case you want. If you don't want to look in junk yards, hang out in the for sale section of pirate. You'll find what you are looking for if you aren't in a rush and usually at a decent price. Also check this boards for sale section.
    I never changed out my column, i thought it would be one more thing to confuse a thief!! I also went the hydro route. It was much more of a pain in the ass since I didn't have the right pedal set at first so I had to guess on alot of things. If you search, you should be able to find a hydraulic setup in a junk yard. It doesn't have to be 4wd, just look for any 85 to 87 half ton truck, 85-92 suburban, blazer, or 3/4 and 1 tons. Just rob the pedal set, master, slave, and bell housing.
    Sometimes people just take the whole transmission so it might be harder to find a bell housing, but it's not hard to make your own bracket to hold the slave.
    We really should do a write up on this. I'm willing to help. Maybe if I get time I'll do the whole thing.
  7. dyeager535
    26,981
    With an '86, a hydraulic setup is going to make life easier (firewall is set up for it), so even if you run across a good deal on a mechanical setup, I say wait.
  8. 4x4_76
    4x4_76 1/2 ton status
    Jul 22, 2001
    628
    Ylämaa, Finland
    So, on my '80, how hard is it to mount hydraulic master cylinder? Cutting, drilling and cursing ahead /forums/images/graemlins/thinking.gif
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    On my '84, there was already a hole in the flywheel that worked great. Put in the parts, and I was ready to rock and roll. Hydro clutch was one of the best things that ever happened to my truck.
  10. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
  11. jays68yak
    jays68yak 1/2 ton status
    Feb 27, 2003
    973
    Gilroy, CA
    I have a pedal and linkage setup from a 79 oneton that I just parted out. Let me know if you want it to do your swap. Email me at jasons68@comcast.net
  12. 4x4_76
    Jul 22, 2001
    628
    Ylämaa, Finland
    I guess best route is to find donor truck where I can scavenge all the parts at once. Problem is that manual Chevys are pretty rare here, and ones that have it, are still on the road.
    I will put on add for parts and hope for best. I already know one 465, but it doesn't have bellhousing, and seller wasn't sure is it really a 465. He wanted $350 from it. Is that a fair price?
  13. 1gmc4x4
    1gmc4x4 Newbie
    Sep 7, 2004
    3
    san jose, ca
    NO
    I got a SM465-NP205 with bellhousing clutch asymbly, clutch, flywheel, (everything) for $200
    I thing $350 is FAIR for a sm465 if it was rebuilt.
    I did the swap to my 69 so its a little(a lot) different then yours but for the most part was really easy. I made a bracket for the swivel linkage and from ther everything bolted right up /forums/images/graemlins/truck.gif
  14. 4x4_76
    Jul 22, 2001
    628
    Ylämaa, Finland
    I was buying winch for my truck today, and I asked about that $350 box. Parts dealer said that who is selling that tranny knows his stuff, and it's cheap if it really is a 465.
    Like I said, they are rare in here.
