Auto To Standard
Discussion in 'The Garage' started by ftcjimmy, Apr 25, 2006.
  1. ftcjimmy
    ftcjimmy Registered Member
    Mar 9, 2005
    61
    ct
    I was considering swapping in a standard tranny. I hvae a 90 Jimmy (tbi). Would this mess with the computer in any way?
  2. virgilh
    virgilh 1/2 ton status
    Sep 8, 2004
    343
    Sacramento California
    a idea
    ive done this swap on a few jeeps ( i know sorry) i had to change the prom chip to one that was for a 4 speed and use a speed sensor on the speedo output i do not know where your speed sensor is on that k5. check the wiring schematics for the 700r4 wires and hide them in the harness. or remove them all together
  3. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Unfortunately that is a swap into an older vehicle with a newer setup .
    What he can do is use a newer setup , and have the speed sensor .
    Or if he used an older setup , use an adapter that would attach where the speedo cable goes , and turns that into the correct signal for the computer .
  5. ftcjimmy
    Mar 9, 2005
    61
    ct
    Niether of my trucks has speedos. Not concerned with it. I figure ill get pulled over for a Vehical Violation before speeding.
