auto trannies, 350
Discussion in 'The Garage' started by ronnny, Feb 26, 2006.
  1. ronnny
    ronnny 1/2 ton status
    Nov 22, 2004
    838
    Newnan GA
    I found me another chevy for a ggod price but says needs tranny rebuilt. But my question is. What is the difference between a 2 by and a 4bys tranny both being 350 trannies. If i got the truck could i just change the tail sections out on the two since i have one for a 2by in my yard or is this not possible. I know very little about auto transmissions. This truck has a 203 w/part time kit. But anyway can i swap tailends of these two trannies or will i have to pay and get someone to rebuild this tranny if i buy this truck?
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the output shaft is longer on the 2wd than a 4wd and won't interchange without swapping the output shaft of the tranny to a 4wd shaft.
  3. ghostrider32
    ghostrider32 1/2 ton status
    Apr 17, 2005
    117
    HOLDENVILLE.OKLA
    Not Only Will The Shaft Have To Be Swapped Out The 2wd Tranny Case Is A Lighter Duty Case 4 Wd Case Should Be A K Case Built Stonger Than The Other
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    the k case is only true for 77-up
    non existent before then
    good luck
