auto tranny question?
Discussion in 'The Garage' started by yunit, Apr 17, 2004.
  1. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    What would cause my tranny to grind when I put it into park? /forums/images/graemlins/dunno.gif My foot is on the brake and I am not rolling. /forums/images/graemlins/waytogo.gif
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    tcase is nuetral?
    did you loose a rear drive shaft?
    something is still spinning.
  3. yunit
    Feb 24, 2000
    3,068
    Oakland, NJ
    Tcases are in gear and the driveshaft's are both bolted up.
    Also, this my my setup.
    350ci stock
    TH400 with manual valve body
    Doubler (203&205)
    axles have 5.13's
    42" TSL's
  4. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    for some reason the tranny is still spinning so the when park prawl is released, it bounces off the slots and sounds like a grinding sound. i would check everything from the 203 range box all the way to the rear end and tires.
  5. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Adjust your shifter linkage or in your case the cable. I have that same problem everytime I swap a trans and have to adjust the linkage to fix it. What is happening is it is not going all the way in to park. Last 3 transmissions I swapped I had the same problem and that was the cure. I know you just swapped that one in so I bet that's the problem.
