auto trannys,transfer cases,good 4.3 Litre, rebuilder 350 in so.NJ
Discussion in 'Engine | Tranny | T-case' started by crossy, Jan 28, 2005.
  1. crossy
    crossy 1/2 ton status
    Jul 12, 2000
    257
    southern ,N.J.
    (2) - Chevy/ GMC 700R4 Automatic overdrive transmissions, with torque converter, fits 82-87 4X4 only,Full-size chevy trucks ,Blazers & Suburbans. Known to have all gears . $100ea. Mileage unknown, worked fine.
    (1)- Chevy/GMC , 700R4 Automatic overdrive Transmission,with torque converter, Fits 83-91, maybe 92 also, 4X4 only , fits Little S10/S15 Blazers and pickups. Rebuilt in 1997. $175.00 Appx 60K miles on rebuild.
    (1)- Chevy/GMC 231C transfer case, Fits 83-91, maybe 92 also, 4X4 only, fits Little S10/S15 Blazers and pickups. Will replace the 207 C used in earlier trucks/Blazers. $150. 90K miles. ( I can UPS this one)
    (1)- Chevy/GMC 208C transfer case from fullsize pickup/Blazer/Suburban,fits 81-87 4X4 only pickups, and 81-89 Blazers/Suburbans. $100 , Mileage unknown, worked fine.
    (1)- Chevy/GMC Complete 1991 4.3L V-6 engine, TBI fuel injected used from 87-92. Can hear run, holds high oil pressure, great running engine. appx. 60K miles on it. used in 85-88 Monte Carlos , 85-91 S10/S15 pickups & blazers, 85-91 Astro/Safari vans and some 85-87 Full size pickups. can hear run. $450 ( can crate $30 & ship at your cost) Frieght company is up to you.
    1984 -350- 2 bolt, bare block with caps, cast crank may need .010 cut. engine will need first oversize bore from water pits. No damage. clean on outside. Block &crank= $75.oo
    1978 350, 4-bolt,
    Complete from 4 barrel intake to oil pan, has correct balancer also. #3970010 block, dated D-7-78 , TDR code. Engine was rebuilt at some point but not sure about when. Runs well, but smokes at higher RPMs, Has high oil pressure, but needs basic rebuild. Bearings size was still STD. when I checked. Selling as a rebuildable core. Engine was steam cleaned on outside also. $225.oo
    1974 350 -2 bolt. Complete from non-EGR early style 4 barrel intake, (has the filler tube) to oil pan. has correct balancer also. good, earlystyle , thickwall #3970010, 4 block casting. A-21-74 date with CMR code. Engine was never apart other than change of intake and I pulled the pan to verify bottom end. Ran on test stand, but smokes and sounds like cam is wiped out. Should Need only a BASIC rebuild. Engine has also been steam cleaned on outside. $150.oo
    I get wholesale parts on rebuild kits and will supply if needed.I do NOT sell the rebuild kits separately. Engines can be crated & shipped. Please Be VERY specific when Emailing please. located in Pennsville , N.J., which is right at the bottom of Rt. 295 and Jersey Tpke. , Delaware Memorial bridge area. Thanx , DAVE
    Dave Cross -856-678-7883 , email all4trux@snip.net
  2. crossy
    Jul 12, 2000
    257
    southern ,N.J.
    ttt please
