Automatic floor shifters...opinions
Discussion in 'The Garage' started by lar300mag, Dec 11, 2006.
  1. lar300mag
    lar300mag 1/2 ton status
    Mar 17, 2006
    258
    TEXAS
    Just trying to decide on which floor shifter to buy, curious to see what everybody is using. Post up
  2. muddyblzr
    muddyblzr 1/2 ton status
    Nov 2, 2004
    623
    houston/san antonio texas
    art carr all the way
  3. ryoken
    Jun 13, 2003
    29,623
    1,379
    Jersey Shore
    what he said....
  4. scooter122983
    scooter122983 1/2 ton status
    Oct 4, 2006
    297
    Fond du Lac, WI
    b&m light truck mega shifter.
  5. CDA 455
    CDA 455 3/4 ton status
    Jun 2, 2006
    8,598
    43rd State
    X3 :D :bow: :haha: !!
  6. destinbeachman
    destinbeachman 1/2 ton status
    Aug 31, 2005
    365
    Florida
    I run a B&M Megashifter and like it just fine.TH350 with manual valvebody.I'm thinking about changing it to something a bit smaller.I like how the shifter in the post above sits on the center armrest.I was thinking about maybe putting a smaller B&M shifter on a small plate mounted beside the forward right corner of my seat.Have to think about it for a few more months:wink1:
  7. SkysTheLimit
    SkysTheLimit 1/2 ton status
    May 23, 2003
    530
    Tampa, FL
    That's precisely what I plan to do with with a B&M Pro Ratchet shifter. I think it will be really comfortable in that location.
  8. BizeeB65
    BizeeB65 1/2 ton status
    Oct 12, 2005
    859
    Louisville, KY
    x 4. But mine has winters performance tags on it! :D
  9. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    I have a 23" tall Lokar. I like it because it has mechanical linkage. I also like how high it sits. I have a 3" body lift and the knob sit about the same height as the heat controls. It came with a switch to rewire the backup lights or neutral safety, whichever you choose.
    I have a cab swapped on from a stick truck so people ask me all the time if it's a 4 speed. I answer yes. then they are amazed at how smooth I am with it on the trail.:D its a 4 speed auto.:doah:
    the mounting hardware is really nice. there is a main peice that bolts to the tailshaft bolts and the side of the trans. the shifter base can go in 5 different spots. the angle at which it leans back is adjustable.
    When you pull it down into low you know it because it down by your hip cause the shifter is so long. has a ratchet feature so you can't downshift without pushing the button in.
  10. bear76
    bear76 1/2 ton status
    Oct 16, 2005
    1,065
    here
    Any pic.'s on said Lokar shifter? Also, do all the lokars "lockout" or is it an upgrade?
  11. gmc4cw
    Jul 19, 2006
    3,907
    west chester, Pa
    I have pics but they are at home. The shifter I bought is the basic setup. so whatever it does is what they all do. was $75 about 8 years ago. they still make it though. check out www.lokar.com
    this is the one I am running. the curve matches the dash very well.
  12. muddermilitia
    muddermilitia ThatTrazerGuy GMOTM Winner
    Nov 10, 2005
    5,742
    76
    NE Illinois
    Im going to build a tubular cener console in my truck and will install the B&M quicksilver shifter. I love the ratchet action!!
  13. ryoken
    Jun 13, 2003
    29,623
    1,379
    Jersey Shore
    Might wanna consider a Hurst if you dig the ratchet stuff...
    Hurst V-matic 2 is the best ratchet shifter I've seen, little nicer built than B&M's offerings at the same price.... Ran em in my hotrods for years...
  14. muddermilitia
    Nov 10, 2005
    5,742
    76
    NE Illinois
    That would definitly be a possibility if I didn't already have the B&M shifter. I will be taking it outta my 2wd K-5 and putting it in my trail-rig
  15. raymos
    raymos Who?
    Jul 6, 2006
    479
    8
    NOR CAL
    how did u make that consol? material?:D i need a way to mount an auto shifter and i was thinking about making one (after i ditch the bench seat) but i dont know ware to start.
  16. muddermilitia
    Nov 10, 2005
    5,742
    76
    NE Illinois
    My brother made one out of wood for my 79 K-5. Its cheap and easy to make. Plus you could always paint it, cover it in carpet, or cover it in fiberglass
  17. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    times eleventeen!
    I semi-frequently hear of or see people who've pitched a B&M b/c it quit working right, but I've never heard of an ArtCarr/Cheetah/Winters wearing out.
  18. muddyblzr
    Nov 2, 2004
    623
    i like art carr because it seems to shift quicker. you can grind the gate from drive to reverse out so you can go from drive to reverse in one motion.
    the b&m ratchet action would get annoying and make it more difficult so get to reverse in an hairy cituation
  19. ryoken
    Jun 13, 2003
    29,623
    1,379
    Jersey Shore
  20. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    I hadn't thought about this until I saw the pic. I have a HURST Promatic2 for trucks, which is cable operated and I'm a total fan of HURST, but the cool thing about a mechanical is you can feel the powertrain rock under load, as in manual tranny. Hmm. I think I'm about to convert to mech. :D
    Pictures would be greatly appreciated, thanks.
