Automatic gear ratios
Discussion in 'The Garage' started by neverendingproject, Aug 24, 2006.
  1. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    Does the torque converter multiply gear ratios as well at torque before it reaches lock up?
    At low rpm, would the 2.48 ratio be more like 4 something, or does it not work that way?
  2. sweetk30
    Nov 1, 2004
    25,538
    538
    horseheads , ny 14845
    the basic concept of a convertor is put a fan in front of a nother face to face. plug one in. watch how it will spin the other fan over time. this is how a convertor works.
    so to answer your question no it wont.
  3. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    So I only get more torque because its not a direct connection? I guess if you get more torque, then you dont need the lower gears huh?
  4. bigblock72
    bigblock72 1/2 ton status Premium Member GMOTM Winner
    Oct 18, 2005
    1,234
    58
    American Fork, Utah
    The torque converter will in fact multiply torque, most converters will almost double the torque at full stall, the less the converter slips the less torque multiplication takes place. It's hard to explain how this happens without pictures but basicly (and very oversimplified) there is a third set of blades between the turbine and the pump inside the converter that redirects the fluid and keeps the fluid from bouncing off the pump blades and and hitting the turbine blades in the opposite direction and causing drag. Instead it bounces off the the stator blades which redirects the fluid the correct direction and gives it a second push and this is where the torque multiplication effect comes from. So long story short stator turns a fluid coupling (very inefficient) into a torque converter that multiplies torque during slippage.
    I'm sure I lost you a by the second line, just run a google and learn all you want.
  5. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    No, I read up on it a bit, but if I plug my 2.48 first gear into the mix, I have a sucky crawl ratio, but i know that there isnt a direct connection, so I didnt know if somehow it got a little when it stalls or slush boxes just are gonna suck period.
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    The crawl ratio on paper looks sucky , but I have video of wheeling with 33's and 3.08 gears that contradicts it .
    The converter works great at low rpm for crawling .
  7. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    This all true. A converter does multiply torque.
    for instance, some of the converters on heavy equipment, such as articulating wheel loaders and scrapers. often have multiple turbines and stators for increased multiplication. with these types of power shift transmissions there is no lockup on the converter and the stators are fixed.
  8. 85-m1028
    85-m1028 1/2 ton status
    Apr 26, 2005
    485
    costa mesa california
    I think the general rule for autos is about half the final crawl ratio than what you would want for a stick.
