Automatic Hubs vs. Manual Hubs
Discussion in 'The Garage' started by gator688, Feb 19, 2007.
  1. gator688
    gator688 Registered Member
    Jan 29, 2007
    27
    Gordon, Al
    Alright got my 87 K5 back today with a 6 inch lift installed and the lift guy said that the noise I am hearing from the front axle is because of the auto hubs, so my question is how hard is it to change to manual hubs and what are the pro's and con's of this swap?
    10 bolt axles-28 spline I think?
  2. bodacious
    bodacious 1/2 ton status
    Dec 29, 2005
    296
    Quitman, Mississippi
    E-Z swap. 1 hour, MAX, if your good with basic tools. The snap rings can be tricky sometimes, tho. DO IT! The auto hubs SUCK! :waytogo:
  3. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    Auto hubs are designed for if you need 4wd coming down a slightly muddy gravel driveway after a decent rain storm... and thats when they are new and in good working shape.
    Switch to manuals, they are much better because you are completely in 4wd, or you aren't....
  4. bigblazer87
    bigblazer87 1/2 ton status
    Dec 20, 2006
    333
    Elk Grove, CA
  5. gator688
    Jan 29, 2007
    27
    Gordon, Al
    where can I find out what spline count or is it just a standered number on all 10 bolts?
  6. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
  7. gator688
    Jan 29, 2007
    27
    Gordon, Al
    thanks didnt think of that
  8. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    should be the same part # for all 10 bolts. 28 or 30 spline only refers to the inner shaft splines. both are 19 spline outer.
  9. bodacious
    Dec 29, 2005
    296
    I've heard people say that they like autos because they don't have to get out in the mud and lock the hubs. To them I say, "LOCK EM IN WHEN YOU GET OFF THE PAVEMENT". This way, if you need 4x, just grab the t-case lever, if you don't, unlock em when you get back to the pavement. It takes all of about 30 seconds to lock/unlock both hubs. Less if it's cold.:D As stated earlier, with locking hubs you know when your in 4x and when your not. With autos, it's a guess till your front end spins, or you're stuck.;)
  10. Dudge
    Dudge 1/2 ton status
    Sep 9, 2006
    351
    Kentucky
    I ditched my auto hubs in favor of Warn standard lockouts. Install was a breeze.
  11. gator688
    Jan 29, 2007
    27
    Gordon, Al
    could that be the noise coming from the front or should I be looking for something else? It only does it when I let off the pedal, could it just be a bad driveline angle?
  12. AZ79K5Project
    Jan 15, 2006
    2,082
    Arizona
    With manual hubs - I know what peope are talking about. Getting all the way out and walking all the way to the front axle can be a real hassle and could take hours. :screwy:
    Automatic hubs - Hope they work when you need them. :dunno: If not, stay in the truck until someone comes to the rescue. I've pulled a couple of people out b/c the auto hubs didn't engage.
    Auto hubs are OK for DD trucks in adverse conditions on public roads. I wouldn't rely on them when offroad.
    Manual hubs all the way.
  13. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    Another thing, if you aren't running a big lift and are in and out of 4wd all the time (like a rancher or farmer say) then just leave 'em locked! Long as you aren't getting a bunch of vibrations from bad joints or too much angle, it doesn't hurt to just leave them in.
    I leave mine locked most of the time in my K5, as I mostly use it around the farm on and off the pavement.
  14. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    here is a step by step with pics http://coloradok5.com/forums/showthread.php?t=168847
  15. obijuan
    obijuan 1/2 ton status GMOTM Winner
    May 18, 2006
    4,009
    San Antonio TX
    i was so totally gonna link that.
  16. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
  17. Dudge
    Sep 9, 2006
    351
    Kentucky
    It could be where the noise is coming from. The first night I took my truck out I blew one of the stock hubs. In the parking lot of a gas station no less. Lol I pulled into the pumps and hit a very very small bump and it popped like crazy. I thought I had broke an axle Lol The stock auto's were in rough shape. I drove it home and got a set of lockouts the next day.
  18. AFUFO
    AFUFO 1/2 ton status
    Apr 26, 2006
    329
    Chesapeake,Virginia
    Manual hubs-
    KNOW your locked, as stated
    Able to do 2 low, if you keep the hubs unlocked.
    More options using a spool, unlock one hub to turn.. or go 3WD to make a fun out of a smaller rig.
    Downside, gotta get outside in the heat/cold/mud/snow, if you ever need it in emergency situation you cant just pop it in 4WD, gotta get out in possibly unsafe territory or no time.. (For example, chasing down a hit n run, or like in the movie Volcano.) Plus you car theives have to get out to lock the hubs if you want to out-run the police offroad =P (A plus, as long as your not the theif)
    Auto hubs
    Opposite of what i just said about manuals.. hoping will lock, cant use 2 low, less options for spools. Can pop in 4wd on icey roads etc.
    My opinion - Automatic for daily driver/emergency vehicle, manual for trailrig/secondary vehicle.
  19. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    I can change hubs in an hour with a 45 minute nap included.:D Seriously....changing the hubs is cake. The snap rings are really easy if you have a basic set of dental picks. Manual hubs are a lot better than auto's. Just remember to put a lot of grease back in when you install the new hubs (holds off mud water from penetrating as long as possible).
    -Harrison
  20. burbanbeast
    burbanbeast 1/2 ton status
    Jan 24, 2006
    103
    Collierville
    yeh ill say from experience i like the warn manuals so so much better than i did the auto lockouts. and someone said it earlier but if you dont wanna risk gettin out in the mud or water or whatever to lock them just lock em as soon as you drop off the pavement
