automatic hubs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 83k5dano, May 16, 2002.
  1. 83k5dano
    83k5dano Newbie
    May 14, 2002
    Waterloo, Iowa
    My stock automatic locking hubs are not unlocking like they used to. Is there any way to rebuild these, or should I just put manual hubs on? What brand of manual hubs are the best?
  2. ArrowheadK5
    ArrowheadK5 1/2 ton status
    Aug 3, 2001
    252
    Northern MN
    It's an easy change to manuals and the only about $65-$95 /pair. Most people here will say warn hubs are the best. The auto hubs are not worth the trouble in my opinion.
  3. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Warn Premium hubs.. Really easy install,and they have a good warranty.
  4. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    Yeah, go manul hubs. Manufacturer is your choice.
    Just unbolt the autos and bolt on the manuals. REAL simple.
    Ken H.
  5. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    I would have to jump on board and say replace them with manuals. As far as brand, I can only speak for the Warn premiums. I have been pleased with mine. I did have one chew up on me, but Warn replaced it free-of-charge, no questions asked.
  6. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    I use superwinch manual hubs. The only reason is they have a lifetime warranty and you can warranty them out at any shop that carries them, you dont have to wait for the manufacture to send you a new set.
    Dan
  7. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    I got Superwinch too.... they are good quality and I like them a lot....
  8. Ben Malinski
    Ben Malinski Guest
    I must be lucky. Been using the auto hubs for rock crawling, driving on beach and gereral off road use for 14 years and never had a lick of problems. I do repack the bearings every year weather they need it or not. When it snows here, I just put it in 4by and away I go. We have an M1009 (Blazer) on another base that is also an 84 w/auto hubs and they run the hell out of it and it's still going! That vehicle is used daily on the target range and is always in 4by. Some are lucky and others....
  9. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    I took my automatics off and went to manuals.
  10. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    When my auto hubs gave me troubles I went with manual Superwinch hubs. Been running them about 3 years now with no problems. I like the lifetime warentee and the fact I can take them back Checker Auto if I ever have problems and get a new set.
    They are a pretty good hub, but they can break if you have a locker in the front and are running big tires.
  11. Blue Meanie
    Blue Meanie Registered Member
    Apr 12, 2002
    61
    southern New Jersey
    i say go manual. i perfer warn, but then again it isn't my vehicle. if you want to test them both out, put one of each on each side and see which one breaks first. LOL have fun
  12. txbartman
    Jun 1, 2001
    1,975
    Plano, TX
    I never had a problem with mine, just didn't like "how" they operate. For example, I had a friend who was just leaving the pavement and hitting the parking lot for an off-road run. As soon as he left the pavement, he hit some bad sand and was stuck. He put it in 4WD, but the front axle would have to turn some before the hubs would ever engage. With manuals, you don't have that problem. You turn them, they are engaged.
    Secondly, how would you know if your hub wasn't engaging or not? If you are open diff'd up front, as most are, it would be difficult to even tell if you were having a problem. Like I said, I went manuals so that I KNOW I am locked and never have a question about it. In addition, there are a great deal fewer parts with the manuals. They are so much easier to remove when doing front end work than the old autos.
  13. XHitman396
    XHitman396 1/2 ton status
    May 3, 2002
    620
    Broken Arrow, Oklahoma
    are these things easy to put in, gotta 87 stock and thinkin bout runnin manuals, never even messed with an axel AT ALL and when i take the auto off will like a million bajillion parts go a-flyin, anyone know a "how to" website or anything? thanx\
    Brett
  14. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    get a chilton manual or haynes i like chilton . anyways they have a good xploded diagram in there . naw there arent to many pieces , none should go flying . id have to find time but i could take some pics of mine taken apart <warn prems>
