Automatic oil temp?
Discussion in 'OffRoad Design' started by snowtoy, Sep 20, 2001.
  1. snowtoy
    snowtoy Registered Member
    Mar 18, 2001
    30
    Norway
    What is normal temp on transmoission fluid in a TH350?
    Mine is almost 100 farenheit
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    you shouldn't operate over about 220, ATF starts to break down. You can get synthetic ATF that's good to higher temps, for a little magin for error. I take the temp of the trans out line so I test the hottest oil, or what should be the hottest oil. I figure if I shut down when it's 220, the rest will be happy.
    Making the world better, one truck at a time.
    SW-ORD
    <a target="_blank" href=http://www.offroaddesign.com>www.offroaddesign.com</a>
  3. AgDieseler
    AgDieseler Certified Scrap Producer Premium Member GMOTM Winner
    Jan 25, 2001
    1,036
    1,091
    Dallas
    Ideal tranny temp is anywhere from 160F to 200F, however 220F is still plenty safe. The GM shop manual says that 150F-250F is the designed operating range for their automatics. Beyond 250F, seals start to embrittle and harden. Things obviously just get worse form there. B&amp;M suggests using their temp sending unit in the upper oil return line (TH700R4). From that, I see temps as high as 210F on a hot Texas uphill climb, but sit at 160F or so for most running around. All this is based on petroleum ATF. With 30,000 mile drain intervals, full synthetic is pretty cheap insurance. As a side note, when behind the Duramax diesel, the new Allison 5-speed automatic sits steadily at 190F no matter what the conditions.
    David Oliver
    '85 'burban
    B&B 6.2L J NA
    T-700
    5.5"lift, 35"BFGs
    *Banks Turbo coming soon*
  4. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    GM probably got wise (for once) and put a thermostatic valve in the trans cooler...
    September 11, 2001--"A date which will live in infamy"
  5. jbissette
    jbissette 1/2 ton status
    Aug 8, 2001
    101
    Idaho Falls, Idaho
    Where is the best place to put a temperature sended for you auto trans at? In the pan, or in the line going to the cooler?
    88 Chevy K1500, 350 TBI, TH700R4, 3" body lift, 33x12.50x15 Tires
  6. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    There's a few different schools of thought on this. I put mine right in the temperature port on my 700. You'll see a plug on the driver's side above the shifter. I did this because I did not have to drill into the pan or splice into the cooler line (sources of POSSIBLE leaks). If done correctly though the pan or cooler line that goes OUT to the cooler are both good places to put a sender too.
    See my rig at <a target="_blank" href=http://coloradok5.com/gallery/Leadfoot>http://coloradok5.com/gallery/Leadfoot</a>
  7. jbissette
    Aug 8, 2001
    101
    Idaho Falls, Idaho
    Is the temperature port a standard size temperature sender? Or do I need a special sender?
  8. slider
    slider 1/2 ton status
    May 7, 2001
    547
    Whidbey Is. Washington
    Summit, B&amp;M and Permacool all make a secondary filter, that uses a screw on filter that has a plug for a temp sender already in the housing.. All you do is put the filter in line with the oil cooler. Permacool and the B&amp;M system sell them complete with a gage. I bought the Summit system and bought a Autometer gage. You now know your temp and the fluid is getting a real filter at the same time. It is a slick system.
  9. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    How much did it run you? how much was the gauge? Thanks
    My Chevy isn't broken, its just out of gas.
  10. slider
    May 7, 2001
    547
    perma cool filter with gage p/n prm-10677 is 79.95 The summit remote kit without gage p/n sum-g4980 is 28.69
    B&amp;M has a gage p/n bmm-80212 for 46.95. I cannot rember exactly what I paid for the Auto Meter gage I bought but it was around 40.00. Hope this helps, all part numbers are from Summits catalog
  11. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Thanks for the info.
    Harley
  12. Leadfoot
    Nov 28, 2000
    3,112
    Well, the one I bought from Dakota Digital came with the correct size sender for the port (I think 1/8" NPT).
