Automatic to Manual Hub Conversion Kit
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fwc, Sep 30, 2004.
  1. fwc
    fwc Registered Member Premium Member
    Nov 2, 2003
    84
    Northern Virginia
    91 Jimmy with stock drivetrain. I am going to replace my stock auto hubs with either Warn or Mile Marker manual hubs. Warns website says that I need an Automatic to Manual Hub Conversion Kit. Do I need this? What does it do? /forums/images/graemlins/thinking.gif
  2. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    No you don't need it. I'm not sure what it does. I put Warn Premiums in years ago on my 89 so bare with me. I believe there's a washer next to the outer locknut that you throw away and then there's a small snap ring that goes outside of that (keep the snap ring). The reason for not using the washer is because the Warn hub will stick out a little too far with it in there. Just take out your auto hub, put in the Warn hub and then put the snap ring on the outermost groove of the axle stub. Should take you about 15 mins per side if you're slow.
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    They will just go on fine . I have a 83 and 89 front at home , and either one will accept my warn premiums no problem /forums/images/graemlins/thumb.gif
  4. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    me too i did the change before i got my 60 and it was easy i did it in the dark at my buddies house /forums/images/graemlins/waytogo.gif
  5. fwc
    Nov 2, 2003
    84
    Northern Virginia
    thanks for all of the info. any one want to argue for or against the warn vs mile marker?
  6. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    i like warn thats all ill buy /forums/images/graemlins/waytogo.gif
  7. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    I put the warn premiums on ny 90 blazer and u don't need any other kits. Just pull the autos out and replace them w/the manuals. They work great and I've never had any problems with them.
    Dan..
  8. mrbill
    mrbill 1/2 ton status
    Jul 1, 2003
    170
    Sugar City, Idaho
    Wow!!! What timeing. Just went throught this change over today and that little washer drove me crazy... finaly decided it had to go!! Then things worked just fine. It seemed too easy. /forums/images/graemlins/eek.gif Thanks
  9. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    I have the Warn hubs on my Blazer and the MileMarker hubs on my '56. I like them both as long as they are the premium hubs. I did need new bolts for the Warns a couple of years ago and Warn sent them to me for free. I'm not too sure about the MileMarker customer service since I've never had a problem with them. /forums/images/graemlins/cool.gif
  10. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    just out of curiosity...why change the hubs? I've had no trouble with my '91 auto ones. Is there something I should know about?!!
  11. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    They're weaker than manual hubs and more prone to something going wrong because of all the internals.
    There's a chance they won't engage when you need them most.
    There's a chance they won't unlock when you want them to.
    Overall, if you don't hammer it offroad much, they should be fine. When they do break or fail to work, though, replace them with manual hubs.
  12. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    thanks. /forums/images/graemlins/thumb.gif
