Automatic Transmission fluid capacity?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BayouBlazer88, Nov 16, 2002.
  1. BayouBlazer88
    BayouBlazer88 1/2 ton status
    Jul 31, 2002
    353
    Lafayette, LA
    What is the suggested capacity of transmission fluid for a TH700R4? I've looked all over my Haynes repair manual and I can't find a suggested capacity anywhere. I've already put in 4 quarts put I didn't get a chance to check it because it was dark. I'll check the level tomorrow morning.
    Matt
  2. 4x4k20
    4x4k20 1/2 ton status
    Mar 17, 2001
    1,699
    williamson ga.30292
    9 quarts aprox. that what a 400 holds
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    It depends what you did.
    If yourebuilt it, it takes about 13-14qts
    If you are changing fluids and filter, it takes about5-6qts or even 7 if you let it drain overnight.
  4. BayouBlazer88
    Jul 31, 2002
    353
    Lafayette, LA
    I just changed the fluid and filter. I added about 4 quarts and the level seems to be ok. thanks.
    Matt
