Automatic Transmission Lines
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Nate87k5, Dec 7, 2002.
  1. Nate87k5
    Nate87k5 Registered Member
    77
    Phoenix, AZ
    What line is the return line and what line it the sending line on a 700R transmission on a 87? Thanks.
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Bottom on radiator = return to tranny
    Top on radiator = entering radiator from tranny
    I can't remember how it is on the tranny itself. Try a search...it's been covered. If all else fails, just use the info I just gave you and follow the lines back to the tranny.
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    does this go for th350 and 400 and 200/250 and 700r4 also?
    thanks
  4. heavy4x4
    Aug 28, 2002
    3,270
    I couldn't tell you for sure, but that's what it is for the 700R4 equipped vehicles.
  5. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
  6. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    What I did with mine is with the truck cold I started it up and put my hand on the lines the first one to get warm was the output and the other would be the input from the tranny.
    Eric
