Autozone A/C compressor
Discussion in 'The Garage' started by pauly383, Sep 2, 2005.
  1. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Anyone else have an Autozone A/C compressor lock up ?
    I only bought it because my originals clutch quit . And the whole thing was 5 bucks more than the replacement clutch . I kept my original one and ate the 10 buck core .
    Got 2 months out of it , Oh well , gonna warranty it and remove the clutch and put it on my original compressor which ran the same gas and worked flawlessly until the clutch died .
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Did you replace the accumulator and orifice tube when you replaced the compressor? If not, then they won't warranty the compressor for ya. :(
    If the previous compressor grenaded, then you also need to flush out all of the lines, evaporator and condensor to get rid of the leftover metal particles. :eek1: Once the system is cleaned out, you have to put a couple of ounces of the proper oil in the compressor, and then add the proper amount of oil to the accumulator. Next, rotate the compressor BY HAND for at least 10 revolutions, to lubricate the compressor and move the oil through it, so that it doesn't suck up a slug of the oil that you poured into it. (If that happens while the engine is driving the compressor for the first time, the compressor will hydrolock and be damaged).
    I got 7 years out of a rebuilt R4 compressor from Pep Boys. Already passed the 2-year mark on a "Factory Air" reman from Advance Auto Parts in another rig. Just installed another Factory Air reman to replace the one that finally died after 7 years.
  3. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Sounds like bad luck to me. I have an Autozone compressor that has worked fine for 2 years so far. Yours sounds like a POS.
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Honestly , no .
    The original one didn't burn out , just the clutch died . So I just removed it and replaced it . The old 22 year ol dhose sprung a leak too , but there was some pressure when I removed the compressor . Used vacuum oil , and new gas from work .
    If they won't warranty it , I guess I am buying a clutch for the original one .
    I definitely need to replace that stuff now . I have seen them after a burn out , yuck .
    Or , since its almost the end of summer , I won't worry about it .
    Maybe its time for onboard air :wink1:
  5. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Honestly man, do an accumulator and Orifice Tube when you put the old one back on. It will be worth your while. Wait till you have the dessicant in that thing blow out into the system and you have to fix the whole thing. You're going to have the system open, might as well do it. It's like $30 for the parts.
  6. cbbr
    Jul 17, 2004
    14,681
    That's what I did with mine. I flushed it also and vacummed it down as much as possible with a venturi.
  7. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Going to replace it now . Dead compressor equals blacky floating crap in system .
