aux battery tray...
Discussion in 'The Garage' started by ryoken, Mar 19, 2005.
  1. ryoken
    Jun 13, 2003
    29,623
    1,379
    Jersey Shore
    ok, i'm ready to do a big Powermaster alt and a dual battery setup.. i looked around some and found the driverside tray at ChevyDuty... is $50 the norm for these? or can i get a better deal down at the local stealership? :confused: :(
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    here, you can get the tray for like $7 and the support for $8 and weld it up your self. or the entire thing is $46
  3. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    my local dealer quoted me 60 so yours is cheaper
  4. carolina k-5
    carolina k-5 Registered Member
    Jan 20, 2005
    58
    columbia, S.C.
    i got mine from lmc truck. complete bolt on.
  5. undr8ed
    undr8ed Registered Member
    Feb 20, 2005
    17
    Spokane, WA
    I was checking around and the least expensive tray/ support combo I could find was about $45... I ended up just welding some bent pieces of iron to the wheelwell. Napa had a tray for like $13 and the hold down for about $6...
    I had a group 31 so it was a fair size bigger than a typical starting battery, so I wasn't even sure that the auxillary tray and support would work. I've beat on it pretty hard and so far, so good :D
  6. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    I paid 46 for the factory tray...it fits so nice and keeps it stock... it was worth it
  7. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    The dealership should want around $36 for it. They only used to be 20-23 a few years ago.
    You can take a passenger side tray, drill the spot welds, flip the "foot" support around, and weld it back together to get a driver side tray. The only difference between a driver side tray and a passenger side tray is where that "foot" support is welded.
  8. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    Might also check the local junkyards. I found mine for $5 with the mounting hardware.:cool1:
