Aux lights into bright lights?
Discussion in 'The Garage' started by SS66, Jun 21, 2006.
  1. SS66
    SS66 1/2 ton status
    Feb 13, 2003
    538
    WI, USA
    Im looking to have my aux two 6inch lights light up with my brights.. what is the easiest way of doing this? Splicing into the wire at the headlight? Is that too much of a load?
    Ive been wanting to do this for awhile but Im not sure of the best way.
  2. dremu
    Feb 27, 2000
    15,966
    458
    East of San Francisco
    The stock wiring is weak for the existing lights; adding more lights directly to the circuit is asking for trouble.
    At the very least, use the factory highbeam circuit to close a relay or two to drive your aux lights; if I were you I'd consider doing relays on your headlights and highbeams as well, as it's a low-buck improvement. See
    http://coloradok5.com/forums/showthread.php?t=164429&highlight=headlight
    -- A
  3. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    As said above. Use a few relays.
