Auxillary fuel tank removal, need advice
Discussion in '1982-Present GM Diesel' started by FWP, Sep 8, 2004.
  1. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    I'm in the process of removing the bed (CC Dually), I have a rear tank that has to come out. If I disconnect the fuel lines from the tank, I'll get air in the lines up to the fuel switch (which is switched to the front tanks now).
    What would be the procedure to purge the air once the tank is reinstalled?
  2. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Depends on how your axuiliary tank is setup. If your aux simply pumps fuel into one of the other tanks, I wouldnt worry too much- those usually have self priming fuel pumps.
  3. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    It's set up like a stock factory tank (I think it actually came out of a suburban)...
  4. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Wait, let me get this straight- You have 3 fuel tanks right now? if it doesnt have an electric prime pump, it will probably let in air one way or another.
  5. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Yup, 3... /forums/images/graemlins/grin.gif Anyway, I was able to get to the nuts in the frame without completely disconnecting the tank. So no worries. Thanks for the help though /forums/images/graemlins/thumb.gif
