Avalanch high steer, who has them
Discussion in 'The Garage' started by blazen91, Feb 12, 2003.
  1. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    I have a set of Avalanch high steer arms, but the one ton tie rod ends I was going to use don't fit the taper. Any one had this problem and what ends are you using? /forums/images/graemlins/confused.gif
  2. Shagnaz
    Shagnaz 1/2 ton status
    Jul 19, 2002
    308
    South Carolina, North Charleston
    Are you come off the pitman arm to the pass. side?
    If so, use the draglink end. Works perfect.
    If you have both arms and you are putting the tierod up on them, I don't know. I haven't gotten that far yet.
    Mike B
    p.s. Are you using the furthest hole out for your draglink?
  3. crwln73
    crwln73 1/2 ton status
    Sep 6, 2002
    362
    Clovis,Ca
    No help.I have the arms,but used heim joints. /forums/images/graemlins/smirk.gif
  4. blazen91
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    I tried all three. The bottom(smallest) part of the taper seems right, but the top(biggest) has about 1/8" gap around it. I called the people who made them for Avalanch and he was really cool. He said to send it back and he will replace it. Thank you for your help.
