Avalanche High Steer arms for D60 - anyone using them?
Discussion in 'The Garage' started by Mudzer, Sep 17, 2002.
  1. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    I am looking into a new Crossover Arm for a Dana 60. Do any of you know much about the Avalanche setup? I figured since I have to buy an arm - I might as well go for the leg too. /forums/images/icons/grin.gif
    I am wondering, do I need the spacers for a Dana 60 GM application with 6" springs? Does ORD make these too? Just looking for options. Lets see your High Steer setups and list where you bought your parts. Prices would help too.
  2. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I'm running the passenger side AV arm, Ford Van Pitman, home made drag link and tie rod. I don't think you'll need the spacer but, not sure. $6 for the pitman arm, over $6 a foot for DOM tubing, Avalanche inserts for the rods, and the arm. That's pretty much it other than the Dodge TRE I bought to eliminate the stabilizer hole...
  3. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    Hey Russ, what are the details on that Ford van Pitman arm? Are you using the OE taper in it, and I would assume it tucks up close to the frame?
    I run a very early version of the Avalanche arm, works fine for me. I would reccomend locktiting the bolts/studs/nuts, and torquing them to spec. Pitman arm is off a Scout, with the end cut off, and a new hole drilled for a heim joint.
    Pete
  4. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    A friend (Mat - NoRulz) hooked me up with a reamer to open the Ford hole up to GM 1 ton DLE size. It slides right under the frame like it was made to fit that exact application.
  5. Mudzer
    3,639
    Missouri
    I already have a Superlift SUP-1104 arm and a Rockstomper dropped draglink, so I am good to go there. Just need to go with the steering arm or arms on the D60.
    Anybody here use the High Steer arms for both sides and have moved your tie rod above the springs?
  6. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Steve Fox for one. /forums/images/icons/laugh.gif I remember some others but the names don't come to me right now... Must get more coffee......
  7. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    not sure of your backspacing, but to regain or increase your ackerman it may be better to rear steer when going high steer.
    that is if you are a believer in ackerman steering
  8. Mudzer
    3,639
    Missouri
    I have gave it some thought. I am hoping to go with 2" backspacing on the rims.
  9. Depdog
    Depdog 1/2 ton status Author
    1,657
    Georgia
    I sent you a P.M. with 3.5" backspacing all I had to grind was the caliper up to the mounting bracket. No bracket grinding at all. Took me about an hour to grind both sides going very slow and careful to make em look nice. I took about 1/8 to 1/4" off of just that small part of the caliper. I say small, it was about 1 to 1.5" wide. I drew a line from one mounting ear to another on the caliper and ground down from the line out. Did a little bit at a time and it worked like a champ. I had to remove none of the mounting ear or the mounting hardware for the caliper. I have no worries about the strength of it. Its WIDE with 3.5", Another 3" would be monster wide.
    Depdog
  10. Mudzer
    3,639
    Missouri
    Hey Depdog,
    Do you know if Keith's Avalanche Arms are the Heim style or DRE? I think they have started making them soley for a 5/8" Bolt instead of being reamed for the DRE.
    Thanks for the info! How is the swap going? Any pics yet?
  11. blk87K5
    blk87K5 1/2 ton status
    Dec 26, 2001
    1,290
    Lubbock, Texas
    Sunray Eng. made mine. Very tough. They don't have all of the holes drilled in them, but they custom make them so you don't need that. The arms would not be that hard to make. Probably have a machine shop do it for 1/2 the cost of Avalanche. /forums/images/icons/wink.gif
  12. Depdog
    1,657
    Georgia
    Keith has arms from RockStomper.
    On the Avalanche arms, on their site it says they are for Bolts or Heim Joints ONLY. I noticed that Steve has TRE's on his though.
    Depdog
  13. crwln73
    crwln73 1/2 ton status
    Sep 6, 2002
    362
    Clovis,Ca
    I run Av arms and wagonermachine tierod & drag link with 4" springs.I would say you do need the spacers.I run the tierod in the rear and the draglink in front.I just finished it 9/19,so I dont really know how its going to work yet.The only problem I see is now my draglink & tierod are close to hitting each other when Im flexed up.If so I may need to fab a pitman arm.
  14. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    The web site is wrong. When (if) you order, just tell them TRE taper...
  15. CK5
    May 19, 1999
    21,622
    701
    CO
    I need to go down to Avalanche and take some pics, they are just down the street from me, they redesigned the 44 and 60 arms a little bit, also they only have 5 holes instead of 7, if you use the spacers they have an interlocking design now.
