Average pinion angle change w/ shackle flip
Discussion in 'OffRoad Design' started by 6.2Blazer, Feb 7, 2005.
  1. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    What is the typical pinion angle change after installing a shackle flip?
    I did some calculations and with 52" springs and the rear mounting point dropped 8" and came up with about 8-9 degrees, sound about right?
    The reason I ask is that I need to do some other mods prior to the flip and want to make sure I'm in the right ballpark for what the pinion angle will be.
  2. redneckdude
    redneckdude 1/2 ton status
    Feb 21, 2004
    578
    Augusta, GA
    I don't know exact measurements, but it seems about right. I shimmed mine 4º already and need prob 2-4º to get it totally correct without a t-case drop. Shimming helped some wiht mine, but the T-case drop helped that much more...the vibes were almost violent before and now i get them from about 20-30 mph that are barely noticable. Just be prepared to shim afterwards if u have a blazer.
  3. folkenheath
    folkenheath Worthless Trash Premium Member GMOTM Winner
    Nov 12, 2004
    4,268
    159
    Wisconsin
    If you have(or get) a CV rear driveshaft it may work out about perfect without shims.
  4. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    7 sounds about right. On a K5, it seems to work out right for a CV joint most of the time. for a ujointed shaft, you have to shim and/or relocate perches, t-cases, etc.
    Most of the time we recommend a CV joint if you're working with a K5.
