awful noise turning right
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by freakpower, May 11, 2002.
  1. freakpower
    freakpower Registered Member
    Sep 26, 2001
    7
    Chattanooga, TN
    I’m fairly new to the Blazer thing, just bought the truck in September 01, and haven’t really fooled with it much since then. I’m OK with repairing most problems; it’s the proper diagnosis I have trouble with—which, of course, is 90% of being a decent mechanic. The point is to just please bear with me if I say anything stupid.
    Anyway, my truck has developed an awful popping and wrenching noise that seems to be coming from the rear end when turning right. It sounds rhythmic, as if it could be related to wheel/axle rotation. Any ideas on the source of the problem? Does it make sense to have a steering-related issue in the rear end?
    Any help would certainly be very much appreciated. Oh, relevant info: ’71 K5, 12-bolt rear, TH350 transmission, 4” lift.
    Thanks.
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    It sounds like the diff is messed up. Pop off the cover and see if there are any chunks or flakes floating around in there.
  3. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    if u have a locker in the rear, it may be it engaging/disengaging
    NITRO
  4. freakpower
    Sep 26, 2001
    7
    Chattanooga, TN
    Thanks for the input. Once you suggest the differential as a potential source of the problem, it makes perfect sense. If I'd thought a little harder, I might have realized that the differential exists to allow the wheels to rotate at different rates as the truck turns. Thanks again for being patient and not calling me a complete moron. Now let's hope things aren't too ugly when I crack it open for a look.
    I'll let you know how it turns out--I may be looking for advice on upgrading to a 14-bolt.
    Cheers.
  5. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I broke my spiders in the 12B and only noticed because the ring gear sent the tooth that broke off into the cover and poked a hole in it...that was fun!
  6. 72Blazerod
    72Blazerod 1/2 ton status
    May 18, 2000
    264
    Vancouver, British Columbia, Canada
    I only had my truck for three weeks before the whole rear end blew up. It sounded like plastic or nylon gears rubbing together for about a week before the BIG BANG! When we pulled off the diff cover I found seven broken teeth and my carrier had cracked all the way through. The only thing that I have left of that rear end is the case. I hope yours is in better shape than mine was.
    Rod
  7. freakpower
    Sep 26, 2001
    7
    Chattanooga, TN
    Well, a month and a half later, I finally had a chance to pop the cover on the differential. Oddly enough, everything looks to be in good shape. No shrapnel whatsoever, and the ring and pinion have nice smooth, shiny surfaces.
    I took the top off (Boone, NC if anybody wants it), can maybe hear things better, and the noise seems to be coming more from the vicinity of the right rear wheel, rather than from the pumpkin. Might that suggest anything else? Or is the differential still the most likely culprit and I should have someone who really knows what he's doing check it out?
    Thanks again for all the help.
  8. JoshA
    JoshA 1/2 ton status
    Apr 9, 2001
    104
    slc,ut
    two suggestions:
    first, CHECK YOUR LUG NUTS!! you might have a loose tire. I've lost a tire before and it sounds like some popping as the tire wabbles back and forth and it only happens going around corners. this is very dangerous, especially with a lifted truck. luckly when it happened to me it was in a '78 monte carlo.
    second you can try checking out your brake hardware. the drums have a lot of things in there that can catch and bind if not installed properly. occasionally you will need new springs to keep everything in place.
  9. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,260
    72
    Humboldt/Pacifica, CA
    Check your ball-joints/tie rod ends, steering box at the frame for cracks, loose u-bolts. Just to name a few other things to check.
  10. BigMac
    BigMac 1/2 ton status
    May 27, 2002
    397
    Fremont, CA
    dont forget to check your u joints while your under there.....
  11. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    my idea would be the tire too. mine did that right before my axel hit the pavement. they grab hard when the hit too.
    just a queation. on my front end the bar on front of the axel. (i'm having a brain fart) the grommets on both endsare shot and need to be replaced. it can move up and down like an inch on each side. also how bad would it be to drill a hole in the center of it to put on a steering stabilizer. mine doesnt have the flattened part. its round all the way across. sorry about jumpin off subject. thanks again
    nathan
  12. JoshA
    Apr 9, 2001
    104
    slc,ut
    you are talking about the tie rod. if the tie rod ends are loose it will make your steering sloppy.
    I would replace them pronto. also, DO NOT drill a hole in it. the results would be very bad. I have a rancho steering stabilizer kit that comes with a bracket that bolts around the tie rod.
    that is the way to go. there are a few companies that make these kits.
