Awwww Man!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MudFrog, Nov 14, 2001.
  1. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    On my way to work this morning... Look down and my volt gauge is dropping like a fly... my stereo cuts off and all.. so I decide to turn around and head home... I almost make it home and the blazer starts spitting and sputtering. I didn't make it quite home but I'm close. So I'm thinking maybe the alternator? The belt was squeling pretty bad when I cranked it this morning, and I didn't check to make sure the belt was still there... had to hurry home and call my boss [​IMG]. So now I'm getting ready to go back out there and see what I can do. BTW as soon as it stalled I tried to crank her and she had no juice what so ever. Any simple things I should look for because it showed no other warning signs... it just all the sudden failed.
    89 K5 Silverado, 4", 33's, 3/4 ton axles
    <a target="_blank" href=http://mudfrog.rockcrawler.com>http://mudfrog.rockcrawler.com</a>
  2. CK5
    May 19, 1999
    21,623
    701
    CO
    Sounds like a classic alternator problem, make sure the belt is tight or even still there, if they are pull the alt and have it tested.
    Steve
    Bandwidth FREE ZONE
    Mall-Running poseur 4x4 with curb-feelers
  3. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    Yeah, alternator. When it went, you were running off battery alone for as long as it would hold. When it, too, went, you stalled. That's why you had no juice to crank it again.
    Once you get your alternator issue fixed, you will need to deal with the battery. If it's new or relatively young, it will probably recharge fine. If it has some age on it, it could be shot as well. When you get your alternator checked, also get the battery checked to make sure it will still hold a charge.
    Brian
    Check out <a target="_blank" href=http://tx85gmcguy.alloffroad.com>My Jimmy</a> with all her projects!
  4. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    It was the alternator or nuclear war. Probably the alt.
    John
    Like to go sloppin' 'round in da mud in a rapid fashion....=)
    <a target="_blank" href=http://coloradok5.com/gallery/albun31?&page=1>See my pics here</a>
  5. k5blazerus
    k5blazerus 1/2 ton status
    Apr 22, 2001
    654
    Bend, OR
    IS it a internal voltage regulator or a external voltage regulator.
    you might want to replace that if it is not the allternator. Test your alternator and if it turns out bad then replace the voltage regulator.
    colin
    Save the whales Harpoon a fat chick.
  6. sosamantx
    sosamantx 1/2 ton status
    Aug 14, 2000
    393
    somewhere in Texas
    if it's an 89, it's internal
    <font color=blue>Steve Sosa a.k.a. "sosaman"</font color=blue>
    <a target="_blank" href=http://sosaman.home.texas.net/carpics.html>http://sosaman.home.texas.net/carpics.html</a>
  7. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    Well I just got it home... The belts were nice and snug... I reckon I need to take it off and have them test it for me. I had to get the wife to jump me... I let it sit for about 15 minutes. That was enough to get me home at least.
  8. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple> Have you taken off the alternator recently ? Or done anything new around it ? Mine squeeled bad and eventually broke apart and left me stranded ........ It was not true and tore up 2 new belts ...... I trued it up and now no more squeel and good to go !
    L8r,
    . Riz . <a target="_blank" href=http://www.geocities.com/rizmonkey>www.geocities.com/rizmonkey</a>
    <font color=purple> BOW CHICKA BOW WOW !
  9. Easy test. Jump start the truck, then unhook one of the battery leads at the battery. If it dies, it's the alternator.
    God has a hard on for Marines, because we keep Heaven chock full of fresh souls!
  10. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    I'll give that a go... a lot easier then taking it out and taking to Advance for testing.
  11. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    yeah but youll burn it up .....
    WHATS WRONG WITH A 305 ?
    81 K10 GOODYEAR 35" MTRS
    TH350 NP 208
    O R D's axles
    NO BREAKAGE :)
  12. Only if ground your wrench out on the metal!
