Axel breather
Discussion in 'Rocky Mountain Region' started by bigdave1050, Mar 31, 2007.
  1. bigdave1050
    bigdave1050 1/2 ton status
    Nov 13, 2006
    119
    Queen Creek Az
  2. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    the piece in the rear end should be replacable. not sure where to get it, the dealer might be discontinued. It might thread in or push in, not sure. I don't know what the stamp means.
  3. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
  4. Jason4x4
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    if you use a tap, put grease on the tap to hold the shavings.
  5. bigdave1050
    Nov 13, 2006
    119
    Queen Creek Az
    OK I know this is a totally noob question, but what is a TAP? is this something used to rethread the hole? I'm still trying to learn as I go.
  6. AZ79K5Project
    Jan 15, 2006
    2,082
    Arizona
    Exactly
    Just make sure, if you do this, that no metal shavings are left behind inside the differential.
  7. bigdave1050
    Nov 13, 2006
    119
    Queen Creek Az
    Got it, thanks I'll have to try this. Belive it or not I discovered that my front axel is also missing the breather connector and tube. I have to wonder what the PO was thinking or what he was doing to the truck.
  8. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    The very question I have asked myself on many vehicles I have bought.:haha:
  9. AZ79K5Project
    Jan 15, 2006
    2,082
    Arizona
    Considering both vent tubes missing, have you opened the covers or checked the condition of the gear oil? Just a thought.
  10. fwdjunky
    fwdjunky 1/2 ton status
    Oct 12, 2003
    499
    Maricopa, AZ
    Well howdy neighbor! Where you at in Queen Creek? I'm over in San Tan Heights myself.
  11. justhorsinaround
    Sep 16, 2003
    6,798
    With this thought in mind, put a rag over the top of the gears to catch the shavings.
  12. bigdave1050
    Nov 13, 2006
    119
    Queen Creek Az
    Yes, I have opened both covers and replaced the fluids and checked all the gears. They seem to be OK; there was no debris in the housing. I found the missing breather tube when I was rechecking the fluid level.
    I live over in Circle Cross Ranch
  13. bigdave1050
    Nov 13, 2006
    119
    Queen Creek Az
    Thanks to all that helped me with this issue. I went to Checkers and Picked up a tap set and two connector tubes (Forget what they called them) and $23 later the problem is solved. Thanks again for those who lent an ear and helped me with the problem....I'm sure I'll have lots more questions in the future.:D
