Axel Identification
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Calclips, Nov 20, 2001.
  1. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    Hello everybody. I'm new to Solid axel 4wd drive systems and am looking at an 82 Chevy longbed (blazers are way too hard to come by in any respectable condition arround where I live). This truck is a 3/4 ton with a 14 bolt rear end. Somebody told me that it was a free floater, is there any way to positively find out if this is true. Also, how good are NP 208 T-Cases.
    Thanks for any help you can give me
  2. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,073
    486
    Grand Rapids area
    I am not sure that the semi-floater (9.5" ring gear) was out in 82. The full-floater (10.5" ring gear) definately was. It is easy to tell the difference. The full-floater has a hub protruding out from the center of the wheel with several bolts on it. If you can see through the center hole of the wheel on the semi-floater, you will just see the outer part of the brake drum. Also, the bottom of the full-floater differential has a distinctive "V" shape to it, while the semi-floater looks more like other axles.
    Check out the guide on this site at <a target="_blank" href=http://coloradok5.com/axleguide.shtml>http://coloradok5.com/axleguide.shtml</a>
    <font color=green>There's nothing like the smell of a rich V-8 in the morning...</font color=green>
  3. Calclips
    Apr 4, 2001
    1,005
    This truck has a large center hub that sticks way out. as far as bolts in it, I'd have to check. What exactly is full floating, semi floating, and non floating anyway? And could the stock axel have been converted?
  4. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    It is a full floater. The truck must be a heavy 3/4, since the semi-floater 14 was out in '81.
    Tim
    70 Blazer CST 4X4 350 SM465 NP205
    87 Burb 4X4 350
    01 GMC 2500HD 4X4 Duramax/Allison
  5. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    81 are you sure, something smells fishy to me !
  6. 82GMC
    82GMC 1/2 ton status
    May 14, 2000
    553
    Seattle Washington
    Well now, Something smells fishy eh? I gotta 81 3/4 ton in my backyard with a SF 14 bolt. My dad bought it new, I know the axle has NEVER been changed!! I can have pics in the time it takes to walk outside and snap a pic! [​IMG] G'Bye now[​IMG]
    I am the hunter Who live's in the darkness, And grows through your fears...... And you are the hunted.
  7. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    a full floating axle hub has two bearings per wheel and is held on to the housing by a nut on the end of the axle tube. the axle bolts to the hub(these are the bolts in the center of the wheel) and goes into the differential to drive the wheels, if the axle should break the wheel will stay on, it is held on by the bearings. a semi or non floating axle has only one wheel bearing and the wheel bolts directly to the axle flange. if the axle breaks, it and the wheel can come off. the full floater is also capable of carrying more weight due to the additional bearings and heavier construction.
    It depends on what you want to do with the truck as to how the NP208 will survive. for general use they are good, they have a good low gear ratio, but the aluminum case, the chain, and the needle bearings inside make them undesirable for serious horsepower or off-roading. The NP205 is best for that with the cast iron case, all gear drive and heavier bearings.
  8. Blazer1970
    1,600
    Old Mission, MI
    Yes, the semi-floater was available in '81. They were all 8 lug in the '73 - '87 style trucks. 6 lug 14 bolt semi-floaters started in the new body style in '88.
    Tim
    87 Burb 4X4 350
