axel ????
Discussion in 'The Garage' started by chops76, Mar 15, 2006.
  1. chops76
    chops76 Registered Member
    May 6, 2005
    38
    south elgin, il
    i have a 1976 blazer with a fully rebuilt dana 44 front end. the lug patter is 6 bolt. i have another dana 44 front axel that is an 8 lug but needs to be reubilt. is there much difference between the two axels? can i pull the hub/axel assemblies from the 8 lug and install them into 6 lug axel? i know one is 3/4 ton and the other is a 1/2 ton. both have identical gear ratio's 4:10 i really dont want to have to rebuild the 3/4 ton 8 lug axel if i dont but i need the 8 lug front hubs to go with my 14 bolt ff corp. rear. i just wasnt sure in the differences with the axels. do they make a 8 lug converison kit? any help would be great. thanks
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Been covered many times :
    Use everything from the spindle out on the 8 lug , and bolt it all to the knuckles of your truck . The outers interchange as the knuckles are the same .
    Then put your 6 lug stuff on the other and sell it as a 4.10 half ton :thumb:
  3. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    What he said - man I type slow...... Check out the "tech" section on the home page - good info on what you are looking to do.
    Tom
