axels axels and more axels....not free
Discussion in 'The Garage' started by supersize75, Dec 16, 2002.
  1. supersize75
    supersize75 1/2 ton status
    Sep 27, 2002
    2,638
    gilbert az......by Phoenix
    ok a week ago I decided to go 3/4 ton or 1 ton here's what I've found in Arizona so far...........
    3/4 ton front rear from Moose + he's a mem =$600.00
    8 lug 76 Chevy, whole truck mabey a d60 /forums/images/graemlins/laugh.gif = $550.00
    *front spicer/rear 14 bolt 3/4 ton=$400.00
    *1 ton rear 14 bolt ff has bearing noise 4.56 gears $200.00
    *3/4 ton rear 4.10 gears $300.00
    *10 bolt front/14 bolt rear 3.73 gears = $700.00
    3/4 ton 2wd truck no title /forums/images/graemlins/frown.gif $200.00
    What do I do? need to make a move real quick /forums/images/graemlins/1zhelp.gif
    the project is close to the end, did I say close ha not really I want it done by Febuary /forums/images/graemlins/rotfl.gif
  2. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    If that 76 chevy has a full floater rear, I'd go that way. Its either gonna be a D44 or D60 up front, and probably has an engine/tranny/transfercae too.
  3. supersize75
    Sep 27, 2002
    2,638
    HOW CAN i CHECK TO SEE IF IT'S A FULL FLOATER?
  4. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> It's almost definately a FF in a truck that old. The front will be a D44 though, the D60s did not show up on CHevys until '77. You can tell if it's a FF for sure if it looks like this -
    [​IMG] </font color>
  5. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Look at the hubs. The axleshaft is actually bolted to the hub. It will look way different than a semi-floater. Also, look at the pumpkin. That big honking diamond shaped pumpkin is the sign of a FF 14 bolt. (the semi-floating 14 has 14 bolts, but the diff lookes more round)
  6. supersize75
    Sep 27, 2002
    2,638
    also just found front 3/4 ton axel 4.10 gears $250.00
  7. Emmettology 101
    May 9, 2000
    8,126
    FL
    If the 76 is definately a 76, then it is more than likely a D44 since they didn't start with 60's until 77..... BUt GM may have snuck a few in early..??..??...
    Go with the best deal that has the axles in the best condition.
  8. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Hey shaggy, since when did 14FF come with 7 lugs? /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  9. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    Wish the had those deals down here
    People want like $1000 for a D60
  10. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> That's custom, man! /forums/images/graemlins/cool.gif You should have seen the D60 when I got it, those were custom 3 luggers. /forums/images/graemlins/thumb.gif </font color>
  11. supersize75
    Sep 27, 2002
    2,638
    I haven't even found a d60 yet /forums/images/graemlins/frown.gif
  12. chevyman_400
    chevyman_400 Registered Member
    Dec 16, 2002
    74
    Billings Mt
    I have two 60 asking $800 each!!!!
    let me know
  13. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Hey Joe, you have the DRW or SRW ones? </font color>
  14. supersize75
    Sep 27, 2002
    2,638
    no thanks the only way I'll probably get a d60 is to buy a beater and get lucky.
    My girlfriend can help on the second part. /forums/images/graemlins/grin.gif
  15. chevyman_400
    Dec 16, 2002
    74
    Billings Mt
    drw but I have found a way to convert them esaly!! /forums/images/graemlins/grin.gif
  16. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I have seen a couple 14bff's in the local u-pull-its. I saw 4 or so in the Ecology yard. A couple were van, and a couple truck. One was a 4x4 with a D44 front (warn standard hubs) &amp; 14bff rear. The U-Pull-It down the street had 2 that I saw also. I don't know the ratio's or carrier in them. I really didn't look too close as I already have my 14bff &amp; 8 lug 10 bolt, so I wasn't really interested. I know the second yard wanted $178 for an axle assembly though. Only thing is you have to go pull it out.
    I also know a guy that has a 3/4 ton 2wd for sale. $150. It has no steering column, and would have to be towed on a trailer or wrecker. But is has the 2wd steering box for xover, and a 14bff rear (don't know ratio or carrier). You could probably sell other parts off the truck and make you $150 back.
  17. Stickseler
    Stickseler 3/4 ton status
    Mar 23, 2001
    6,503
    Northern Virginia
    Being reliable is a major goal for mine. I like to hit the back wood trails that don't see much use. So The mods I'd recomened would be: 3/4 Ton axles (cheaper then 1 Ton, but 1 Ton is better) and either a 4" or 6" suspension lift, and 33" to 36" tires. Now I don't know how you feel about trimming fenders, so I'll leave that one alone. That'll get ya out in the woods. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  18. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Whats up with that ?????
  19. Emmettology 101
    May 9, 2000
    8,126
    FL
    Hey, I see your in Gilbert, AZ! Thats Shannon Campbell country! Man, that woudl eb sweet to live around there. I would love to visit his shop sometime!
  20. supersize75
    Sep 27, 2002
    2,638
    checked out ecology this morning, a selection to say but about 300.00 per axel after core and tax.
    To my suprise I didn't see any d60 layen everywhere like I had dreamed. /forums/images/graemlins/frown.gif /forums/images/graemlins/rotfl.gif So when you AZ guys comin over to check out my two blazers? pm me
