Axillary Transmission cooler question
Discussion in 'The Garage' started by opfor2, Jun 28, 2006.
  1. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    About ten years ago I installed a large stacked plate axillary transmission cooler in front of the radiator and in line with the stock radiator cooler. THEN the other day I finally realized that I installed it the wrong way. The transmission fluid flows into the external cooler first then the radiator cooler. Now my question is should I change it so that the fluid goes into the cooler in the radiator first and then the external cooler or leave it the way it is?
    thanks
    Dan..
  2. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    I would say change it so it goes to the radiator and then to the external cooler.
  3. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    Fluid should flow into the radiator, leave the radiator to the external cooler, then back to the transmission...
  4. thfonz98
    thfonz98 1/2 ton status
    Feb 19, 2005
    319
    Salinas, ca
    im going to install my b&m tranny coller as ive read in other threads(as ive searched before about it) aux first to cool then the radiator (TOO COLD IS BAD TOO) then to tranny.
  5. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    If its been working for 10 years, it ain't broke...... don't fix it
  6. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Ain't nowhere in CACA that can get "too cold".:haha:
  7. Storm Trooper
    Nov 24, 2000
    4,640
    I'd go with this too. The only reason I could see having it after the rad. is so if your motor was overheating it would help protect your tranny better.
  8. opfor2
    Oct 28, 2002
    375
    Ventura County, CA
    I agree 100 % with this statement!!!! I really don't want to mess with it so I'll just leave it.
  9. fabjunkie
    fabjunkie 1/2 ton status
    Aug 23, 2005
    1,580
    Dallas Outskirts
    I'll second this as well as fifth or so to this
  10. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    Well I will 6th it then.
  11. theperfectgarage
    theperfectgarage 1/2 ton status
    Oct 5, 2005
    988
    tucson arizona
    There is always much debate on this subject. I say If you drive it year round and have cold winters, leave it as is. Hitting the rad last insures the fluid is not too cold.
    In hot country, I use just the cooler.
  12. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    Install a tranny gauge, that will tell you what you need to do. If it always run in range then I wouldnt worry about it. If it runs too hot then you know you need to chenge it. But I would go with the aint broke dont fix it creed.
  13. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    ten years ago? not broke=dont fix.
  14. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    I agree...of course here in Montana, that would be the right way to install it though...
