Axle alignment Question
Discussion in 'The Garage' started by k5baby, Mar 15, 2005.
  1. k5baby
    k5baby Registered Member
    Jun 7, 2004
    62
    Prattville, Alabama
    maybe someone can help me out. When measuring on my 72 k5 from front right axle to the back right axle, then doing the same on the left side I came up a 1/2" short.:confused: Is this normal? I had a CHEAP genuine gear Quick Lock and it kept disengaging while driving down the road going in a straight line at any speed. Could this have caused it?
  2. primr87
    primr87 Registered Member
    Feb 15, 2005
    20
    placerville, ca
    Im thinking that a 1/2 inch difference from side to side could be a problem or a really saggy spring, but thats just me, dont know about the quick lock
  3. Canadianbuilder
    Canadianbuilder Registered Member
    Jan 23, 2005
    31
    Thunder Bay Ontario Canada
    You might have a broken center bolt in one of your spring packs and the axle has shifted slightly on the spring.Or your frame has been tweaked abit and isn`t quite square from corner to corner.It could be a cause of your diff problems as the truck was probably "dog tracking" as it went down the road.
  4. k5baby
    Jun 7, 2004
    62
    Prattville, Alabama
    that's what I thought. the pass. side bottom leaf spring is kicked to the side about a inch. the others are still in line. how do you fix this problem?
  5. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    You def want your axles to be inline! and would cause a locker to keep disengaging as it thinks it's turning the whole time.
    Jack up your truck, put an axle stand under the chassis rail and lower the jack to take the weight off the axle. Undo the spring hanger u bolt nuts. Lower the jack more until the axle just starts to drop away from the leaves. Take off the top plate (if this is the front one you'll have to undo the sway bar bolt if applicable.).
    On top you should see the centre bolt nut. Turn it and look at the bottom end. If it all turns.....look for another problem! If it's broken, drop the axle further, pull out the busted parts and slip in a new bolt. Job done. (well...never quite that easy...but you may be lucky!:grin: )
  6. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
    One trick that I've found useful is using two C-clamps, one on either side of the center pin, to clamp the leaf pack together before reving the pin. That way the leafs don't all come appart.
  7. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Unfortunately , it is the locker at fault . I tried everything on mine , made it better for awhile .......and it came back:( I tried new thrust washers , synthetic flud , everything including air pressure and rotations with the closest matches in the back . These are made by tractech , they are actually EZ lockers , and think they made a batch of bad ones , or boxed wrong some other 30 spline applications parts in our 12 bolt boxes :mad:
    I got mine at 4 wheel parts before I knew better . They wanted me to bring it in and pay them to look at it before they would warranty it ....even though the owners manual said I could box it up and bring it in myself .
    Its sitting in a box now for the project truck where I can use it without worries of street manners .
    I fixed my truck by getting a Lockright at 4 wheelers supply :D
  8. k5baby
    Jun 7, 2004
    62
    Prattville, Alabama
    thanks!! i'll work on the center bolt in the springs when it get's back from the paint shop.
    I originally put the quick lock in after it sat up for 10 years and I drove it not thinking to check the diff. fluid, (how dumb was that?!!) and burned up the ring and pinion, instead of putting spider gears in I opted for the cheap locker to get me by till I could afford a Detroit Locker. I still have a quick lock in up front and have no problems.
