Axle Alignment
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 86K5TrailBlazer, Jul 20, 2001.
  1. 86K5TrailBlazer
    86K5TrailBlazer 1/2 ton status
    Apr 24, 2001
    436
    Orange,CA
    Hey Guys well, Im finnally in the process of lifting my K5 (6" 36" SS-TSL's) well after spending nearly all day grinding the welds of the &#@$! spring perches I rolled it under the k5 for final alignment and fitting. Then I started to wonder, what should I do to align everything properly, im putting in a 14BFF in place of the 10bolt. BTW what did you guys to to take the freaking perches off.
    Many Thanks *L*
    __
  2. Gold Rush
    Gold Rush 1/2 ton status
    1,498
    First of all I DID NOT TAKE OFF THE SPRING PERCHES !!!!!!!! I used a 1980 3/4 ton Chevy 14FF and it bolted right into my 75 Blazer.
    David 75K5
    <a target="_blank" href=http://www.extremeblazer.com>http://www.extremeblazer.com</a>
    [image]http://www.extremeblazer.com/sideapproachL.jpg[/image]
  3. bandit
    bandit 1/2 ton status
    Mar 4, 2001
    690
    Ellensburg Washington
    torch ive done it a few time jsut dont nik the tube torch it then grind the rest and iv only done it to set pinon angles
    AJ
    Soon to wheelin spot near you
    Project Harvey[​IMG]
