axle bearing removal
Discussion in 'The Garage' started by mrpoorboy, May 12, 2005.
  1. mrpoorboy
    mrpoorboy Registered Member
    Feb 21, 2005
    84
    hillsboro, oregon
    how do i get the axle bearings out of a 14 bolt sf? would a slide hammer work? or would that crush them? installation tips? any help would be great. thanks
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    which bearings are you talking about my 14FF only has carrier bearings which came right out and the hub bearings which both of them come out the back side of the hub the outer bearing is held in by a snapring. Remove the seal and the inner bearing comes right out. remove the lockring and the outer bearing comes out the same way as the inner bearing.
    OOPS Sorry did not see you had a 14SF. If you ever get a 14ff this is how the bearings come out.
  3. dyeager535
    26,980
    First thing I say about axle bearings is, are you sure they are bad? You've pulled the axles and seen that they are chewed into? Just saying this because of all the noises I've ever had from a rear end, the axle bearings were never a problem, and ALWAYS a hassle to replace.
    I believe the assembly is identical to the 10 bolt, only larger, so slide hammer is the only way to get them out. They usually come apart when you use the hammer on them.
  4. mrpoorboy
    Feb 21, 2005
    84
    hillsboro, oregon
    i bought the axle not knowing what it has been through. i would rather replace the bearings just to make sure. i hope a slide hammer works. thanks for the help
  5. jhellwig
    jhellwig 1/2 ton status
    May 7, 2005
    420
    Bonaparte, Ia
    It is eaisy to do. You will probaly pull the inner race out first. The berings always seam to want to dissitigrate.
