Axle Bearing
Discussion in 'The Garage' started by TxasTerry, Oct 14, 2006.
  1. TxasTerry
    TxasTerry Newbie
    Aug 28, 2005
    3
    Texas
    I own a 91 Blazer and just had the drivers side rear inner axel bearing eat itself. Can someone tell me what might be involved in fixing this? I am trying to determine whether I should try to tackle this job myself.
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    its not to bad of a job, you will need to pull the diff cover and pull out the axle shaft, then use a slide hammer to remove the bearing then install a new bearing and seal put the shaft back, put the cover on and fill up new gear oil and your good to go
  3. pedro57
    pedro57 Newbie
    Sep 30, 2006
    cortez
    That's right, simple enough. Just look at the axle surface where the bearing rides. If it's damaged you can buy a repair bearing or you'll have to replace the axle.
